Transmission fluid change 50k miles
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by iceman13, Jul 1, 2018.
  1. iceman13
    iceman13 Member
    134
    102
    US
    2014 Prius c
    Do I have something to worry if I change my transmission oil now at 50k miles since it hasn’t been changed ever? As many of you know it’s common knowledge that changing the trans oil at higher mileage when it has never been done can cause problems in normal automatic transmissions.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    Nope, change away;).
    I waited to change our 2010 Prius II’s until 140 k miles, and wished I would have done it sooner.
    As you know, this is not a normal transmission, so no issues:).
    Good luck with your fluid drain and fill(y).
    JC91006, Mendel Leisk and iceman13 like this.
  3. iceman13
    iceman13 Member
    134
    102
    US
    2014 Prius c
    Thanks!
    Raytheeagle likes this.
  4. JC91006
    16,482
    8,400
    I changed for the first time at 170k miles.....I'm at 171k miles now and I'll let you know if it fails
    iceman13 and Raytheeagle like this.
  5. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    It have any odors or a color other than black:whistle:?
  6. JC91006
    16,482
    8,400
    No odors, just some air gets released. Not sure where the air comes from.
    Black is about the only color.......
  7. iceman13
    iceman13 Member
    134
    102
    US
    2014 Prius c
    Wow! Air released... That is interesting
  8. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    Ours at 140 was black. Ran fine for the next 33 k miles until I drained and filled again.
    That was purple upon exit :).
    Next change will be around 220 k miles and hopefully in the same condition (y).
  9. JC91006
    16,482
    8,400
    This has occurred before on a different high mileage change. Air comes out when you open the drain plug
    Raytheeagle and iceman13 like this.
  10. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    I don’t remember that, other than depending on how you drain (leave the fill plug in or not).
    I drop the fill plug first then drain away;).
    Don’t forget to crack the fill bolt first just in case it doesn’t want to release(y).
    JC91006 and iceman13 like this.
  11. JC91006
    16,482
    8,400
    Some have suggested every 60k miles would be a good interval
    orenji and Raytheeagle like this.
  12. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    Another suggestion was to change early.
    Did the RX450h At 6800 miles and it was purple:).
    They have a magnetic drain plug on the front differential and it had some fillings in it:(.
    But got it out of the way and ready for 60 k miles change(y).
    padroo and JC91006 like this.
  13. padroo
    padroo Senior Member
    2,763
    2,250
    The Prius transmission is more like a gearbox than an automatic transmission. The fluid is just there for lubrication and cooling more like a standard transmission.
    iceman13, JC91006 and Raytheeagle like this.
  14. Mendel Leisk
    38,735
    Just my 2 cents: change it at one year mark or 10K miles, whichever comes last. Then stretch them out, say addlitional 30K, 60K, and so on.
    padroo, Raytheeagle and JC91006 like this.
  15. orenji
    orenji Senior Member
    5,884
    3,486
    60k is a good number, sooner is better.
  16. Mendel Leisk
    38,735
    I've done 3 changes:
    15K (kms) <by far the darkest drained fluid
    40K <marginally darker
    65K <very clean, don't think I'll be doing any more, for a long time
