Transmission Fluid change Gen1
Discussion in 'Generation 1 Prius Discussion' started by Nelsonprius, Nov 9, 2019.
  1. Nelsonprius
    Nelsonprius Junior Member
    72
    Nelson, BC Canada
    2001 Prius
    I
    Can anyone confirm there is no transmission fluid check dipstick, just a plug bolt on the front above the drain bolt with which to check, add?
  2. Josey
    Josey Active Member
    305
    117
    Virginia
    2003 Prius
    I am 99% certain that there is no way to check it. It it hasn't been leaking assume the level is correct. Drain and measure what came out. Put back in the exact same amount.
    I can't tell you where, exactly, but there are instructions out there on the web.
    Nelsonprius likes this.
  3. ChapmanF
    18,536
    You check by comparing the level to the fill opening.
    It usually doesn't go away by itself, so the usual reason for checking is refilling after a fluid change.
