Transmission fluid in 2013 Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Allison Meggison, Feb 28, 2020.
  1. Allison Meggison
    Allison Meggison Junior Member
    71
    El cajon
    I’ve had my 2013 Prius for about a year and a half , she has 266k miles and the transmission fluid has not been changed since I got it. I’ve put about 80k miles on it in the past year and a half and I was under the impression it could be dangerous to change the fluid due to the sealed system. Any input ?
    49,492
    Idk if any testing has been done, but most here advise changing because it is not a regular automatic transmission
    Also, it is not hermetically sealed, it does have drain and fill plugs.
    pjksr02 likes this.
  3. Mendel Leisk
    38,727
    And I believe a vent plug, right on the top. Drain-and-fill away. (y)
