Transmission fluid leaking after fluid was replaced
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 4HisGlory, Dec 30, 2017.
  1. 4HisGlory
    4HisGlory Junior Member
    San Diego, California
    Hello.
    We recently had the transmission fluid replaced on our 2007 Prius (114,000 miles). I noticed that it is now leaving a 3" wet spot under the car beneath the oil drain plug area. I can't see where it is leaking from. I checked the transmission fill/drain plugs and they are dry.
    Does anyone have any idea what's going on? Might the leak be caused from overfilling?
    Thank you in advance,
    Tim...
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    If the dealer did it very good chance of overfill.
    They love doing that with motor oil.
    It takes 4 quarts of fluid. It’s bright red pretty easy to see where it’s leaking from but hard to get all the way under there to look at it unless the car is jacked up.
  3. johnjohnchu
    johnjohnchu Active Member
    211
    104
    It is almost impossible to overfill. Perhaps the tech did not use two new washers and/or torque to the correct spec.
    Mendel Leisk and Raytheeagle like this.
  4. Dxta
    Dxta Senior Member
    1,932
    769
    Lagos
    Take pictures and post here, maybe that might help.
  5. bisco
    51,155
    is it wet on the bottom? wipe it clean and then dive back under after it starts dripping again. they shouldn't have touched anything but the plugs.
  6. Mendel Leisk
    40,586
    Who changed it, dealership? Was it the specified Toyota ATF-WS fluid. Do you have an invoice indicated how many quarts or liters were used?
    I would get back to them asap, and take it real easy with the car in the interim. I'd second some kind of mess up with the fill or drain bolts and/or their washers.
    Also, I've got a vague recollection: someone here reported having a change done, way too much fluid was put in, and it was coming out, through a third bolt at the top of the transaxle if I recall correctly. The engine bay had some fluid sprayed. Have you popped the hood??
    Raytheeagle and bisco like this.
  7. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    THIS. Why would that NOT be the first thing that you think of doing ????
    Transmission fluid is pink oily fluid.
    Engine oil is usually light brown.
    Coolant is green or orange and smells sweet.
  8. 4HisGlory
    My son was in Sacramento - his first time servicing the car. It was a small auto shop. I'd have to drive 500 miles to get back to them - a bit far. He asked them and they used ATF-WS fluid. Invoice says 4 quarts.
    I am 95% sure it's tranny fluid - reddish, not brown. I'll look again when I have time (just to confirm).
    I don't have an actual photo, but attached is a photo from the Internet. I circled in green where the fluid seems to drip down. I crawled underneath, but couldn't really tell exactly where the fluid was leaking from.
    I'm surprised because isn't the transmission much further back?
    I'm also surprised that overfilling could cause a leak. Doesn't make sense to me. image.jpg Then again, I'm a hack, self-taught DYI mechanic.
    Thanks again for you replies :)
  9. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    If it’s the green box on the picture, that’s the oil pan;).
    The oil drain plug is just above the left side of the green box.
    Are you sure it’s trans fluid:whistle:?
    Keep us posted (y).
    #9 Raytheeagle, Dec 30, 2017
    valde3 and Mendel Leisk like this.
  10. 4HisGlory
    Yeah, I know that's the oil pan
    The fluid is red and it seems to be coming from rather high up, and finally making its way down along the passenger side of the oil pan.
    I did pop the hood a couple days ago and didn't notice any fluid sprayed in the engine bay.
    I don't think I'll be able to look underneath until after new year's, so... Happy New Year everyone!
    Mendel Leisk, Raytheeagle and SFO like this.
  11. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    What coolant are you using in your Prius?
    If using the long life coolant, that is red;).
    Have you changed the water pump out or is the water pump leaking? What is the level of coolant in the engine loop?
    Happy new year and keep us posted(y).
  12. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    751
    Delaware
    they might have slopped some fluid during the change, and now its dripping off. coolant is pink and water pump might be leaking. some trannys will leak out the vent if overfilled; I don't know if prius will do that. you need to get under it with a strong flashlight right away to figure out whats going on before damage occurs. and likely you will need to remove the plastic panels under the engine to see the problem.
  13. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    Sounds like there might be Long Life Coolant (red coolant) in the engine loop.
    My bet is the radiator cap isn’t secured or the water pump is finally due for replacement, given this happened after “servicing” ;).
    #13 Raytheeagle, Dec 31, 2017
    uart likes this.
  14. dolj
    dolj Senior Member
    8,217
    4,187
    Wellington, New Zealand
    This is incorrect. Gen II are all factory filled with SLLC (pre-mixed). The Gen I used LLC (concentrate). If you had a '07 with LLC, then that was after the fact. There is nothing to stop you using LLC either, it's spec'ed life is shorter is all, so you will be changing it more often.
  15. Mendel Leisk
    40,586
    100% coolant would be handy in cases where the system was water flushed. Too bad SLLC only comes pre-mixed.
  16. 4HisGlory
    Okay, here are a couple of photos, one taken from above and one from below.
    It looks like red coolant on the inside of the water pump flywheel (1st photo) and below the water pump shaft is damp and has a coating of pink crusty stuff. The area of the engine below the water pump also is damp with pink crusty residue (2nd photo). The coolant reservoir is empty, and the radiator is low (the cap is wet, but I can't see the top surface of the fluid).
    I assume this is conclusive evidence that the water pump is a goner, correct?
    I watched a couple of YouTube videos and the replacement doesn't seem too difficult although it's pretty tight quarters. Do you normally remove the inside wheel well to have easier access? How do you know if you've tightened the tensioner bolt enough?
  17. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    Looks like a failed water pump ;).
    Hope the level didn’t get low enough to throw a code on the dash indicating a high temp in the system.
    But clearances are tight, yet doable:).
    Good luck(y).
    uart and edthefox5 like this.
  18. edthefox5
    10,096
    4,831
    Clearwater, Florida
    Ray is correct thats the fear as Toyota in there infinite wisdom never put a engine temp gauge in the dash so the engine can get pretty overheated before it throws a check engine light. Aluminum head.... not good.
    Take the black plastic cover off the top of the radiator and theirs a rad cap under there. I bet the rad is pretty low. This car is weird the rad can be empty but the overflow is full. Wacky...so you have to check the rad itself.
    Never did a water pump on this car but many many posts on replacing it. Search forum.button.
    Sean2005Gen2CA, uart and Raytheeagle like this.
  19. padroo
    padroo Senior Member
    2,763
    2,251
    Put a piece of cardboard under the car and let it drip overnight then pull it out and then you can tell for sure what type of fluid it is.
  20. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Yeah that's 100% what the eagle and the fox say. Residue of dried coolant seeping from the water pump seal.
    Get the radiator (the actual radiator not just the plastic reservoir) topped of straight away, then look at getting the water pump replaced soon.
    BTW. Always make sure the engine is cool before removing the radiator cap.
    Raytheeagle likes this.
