Transmission Gen ll Drain and fill or Flush?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Fred14, Dec 19, 2015.
  1. Fred14
    Fred14 Junior Member
    40
    Southwest
    My 2006 has 108,000 miles. An independent shop said one can not flush the transmission as you can not put torque on the wheels. A dealer says they have a machine to do it. Who is right? Can one flush and fill the transmission?
  2. xliderider
    xliderider Senior Member
    7,895
    3,129
    Honolulu, HI
    Yes, the transaxle can be drained and filled.
    Neither the shop or the dealer is right. The Prius transaxle oil change is a simple drain and fill, similar to an oil change. Actually, simpler because there's no filter to change. There is no machine required.
    #2 xliderider, Dec 19, 2015
    dorunron likes this.
  3. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    Well said xl, I could not have answered it any better. (y)
  4. Mendel Leisk
    38,899
    Isn't it a bit of a bear to DIY, due to trapped air? I do oil changes in my sleep, and I've done coolant changes on a lot of Hondas, but I've heard Prius coolant change is more difficult.
    Also, I would just use the expression drain and fill, not "flush". The latter implies running a lot of water through the system, not needed, leaves mineral deposits, questionable dilution and bad for the environment.
  5. roamerr
    roamerr Member
    135
    43
    Winston-Salem, NC
    Tranny is easy. No air trapped. Coolant is more difficult since air can get trapped. This thread was about tranny.
    iPhone ?
  6. Patrick Wong
    18,200
    6,479
    We need to be clear about whether the discussion is about replacing 1) the transaxle ATF, or 2) the inverter/transaxle coolant.
    If 1), all that is required is to drain and fill the transaxle. A flush is not necessary or useful.
    If 2), then it is necessary to drain and refill the coolant and then work to get the air out of the system, which is not particularly difficult.
  7. andrewclaus
    andrewclaus Active Member
    993
    324
    Golden, CO
    Assuming it's about the ATF:
    Yeah, the Prius CVT is a whole different animal than a regular automagic transmission. It does not use fluid under pressure to do actual work, its just an oil bath for a few gears and two electric motors. No hydraulic torque converter, no radiator for the fluid.
    And Toyota doesn't even officially recommend ever changing it, and many never do. So don't sweat it too much. But so many smart people here recommend it. It is a very simple project to DIY, and only about $40 in fluid.
    BTW, I would drain and fill the coolant, too, both engine and inverter, if it hasn't been done yet. By coincidence, that takes about $40 in fluid, too. And Toyota does recommend that.
  8. Fred14
    40
    Southwest
    Thanks for the info. I assume then from the info, that there are no hydraulic lines inside the CVT. that would benefit from a flush. and if one really wanted to one could put it on a frame lift and put it in gear to flush it. I will have it drained and filled. Thanks Fred
  9. Mendel Leisk
    38,899
    I'd be reluctant to let those guys near it, considering all the misinformation. Be sure they use Toyota ATF-WS. Refill level is set by filling with the car levelled, until it starts coming back out of the fill hole.
  10. edthefox5
    edthefox5 Senior Member
    10,096
    4,810
    Clearwater, Florida
    The run it through the gears bit is for the valve body which a Prius does not have.
    You could go to a guy/shop that uses one of the new machines that vac out the old fluid and then pump in the new fluid but that bypasses the best part which is taking the dump bolt off and investigating the magnet end for metal and then dumping the fluid in a a large wide container and looking at that fluid in the sun which will reveal any non ferrous metal not caught by the magnet. The best part of the vac machines is it bypasses the messy dump part. After a vac you can pull the pan off an auto and its pretty dry no mess. No pan on our cars.
    It is for all intents and purposes a manual trans. If you suspect the trans fluid is very very bad I would do multiple trans fluid dumps. Do my test and see. But if the trans is running great a vac machine (
    car not on just suck & dump through the input hole) is a pretty good idea. Fast and possibly cheap.
    Maybe cheap enough to do it again in 3000 miles.
    Alot of people myself included send out there trans fluid to have it analyzed. See the trans fluid stickys at the top of the forum.
    Btw, I highly recommend changing the Inverter/trans coolant also. That system is very hard on that coolant. Really very easy there's many youtubes about it. If you do get that changed as an interesting sidenote make note of the change in turbulence between the old fluid and the new fluid in the Invert coolant container. The coolant pump works much better with pure coolant. Much more aggressive pumping action. Thats a dump and fill. No vac possible.
    I do my trans fluid & Inverter coolant every 30,000. I follow Luscious Garage intervals. (lusciousgarage.com)
    I notice a slight increase in mpg's also when the I coolant is changed also. Car is very happy when Inverter very happy.
    #10 edthefox5, Dec 20, 2015
    Fred14 likes this.
