Transmission leak
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Mel Crittenden, Feb 8, 2025.
  1. Mel Crittenden
    Mel Crittenden New Member
    Yuma AZ
    Hi there,
    My 2008 Prius has developed a transmission leak and apparently there is no way a regular person can check the level cause it’s a sealed system. The drip is by drivers side at front. I am really concerned cause I don’t know what needs to happen. Dealer said they want 300 just to check levels. Is there anyone out there with a 2008 that has had this happen. Car has 168k miles on it.
    Thanks in advance for any advice.
  2. Tombukt2
    Tombukt2 Senior Member
    12,214
    2,155
    Durham NC
    Well you wanted to determine where the drip is coming from I doubt it's the transmission literally usually it's a input shaft seal or output shafts here where the CV joint goes into the transmission You should look there real quick and see if you see an obvious drip there If it is there that means when it's running and spinning it could be slinging some out so it may have the whole area there nice and shiny and wet If that's the case that's an easy seal to replace and then maybe it's time for you to change your transmission fluid anyway it's not that difficult and $300 holy cow to check the level yeah okay it's like checking an old rear end in a truck or a car You put it level you have the plug out the upper plug You stick your finger in it and the tip of it should just get wet You don't bend it down just stick it right in your pinky It should come out with some red on it not from the threads from the level of the transmission.
    Mel Crittenden likes this.
  3. BiomedO1
    BiomedO1 Senior Member
    2,821
    1,499
    SacTown, Ca
    It's NOT a sealed system. If it was, how's the dealership going to check it for $300???
    You'll find a 10mm hex plug at the base of the transmission, drain plug. On the other side is another 10mm hex plug, up near the half-shaft - the fill port. That's where you check the ATF fluid level. If the car is level, fluid should drip out - if it doesn't your low. Fill with Toyota ATF WS until it begins to drip out.
    Hope this helps.....
  4. Mendel Leisk
    40,584
    Repair manual fluid level check attached. Toyota didn’t include a fluid change instruction for gen 2. Dealership’s $300 USD quote to do this is preposterous.
  5. MAX2
    MAX2 Senior Member
    1,436
    483
    101
    Third planet from the Sun
    Do you have any photos or videos of the location where you saw the leak?
    That would help us give more valuable advice.
  6. Mendel Leisk
    40,584
    Are you able to raise it yourself say with floor jack or ramps? What’s the parking situation? If possible, wipe everything down then monitor.
    there’s a link in my signature regarding third gen transaxle fluid change, which may be useful. (On a phone turn it landscape to see signatures).
    #6 Mendel Leisk, Feb 9, 2025
  7. Mel Crittenden
    Yuma AZ
    Thank you for the advice
  8. Mel Crittenden
    Yuma AZ
    I don’t have any photos. I just started noticing the driveway had a spot and then had my daughter drive it in the garage and I put cardboard underneath it and there were 2 small drops overnight. I took it to my mechanic cause I thought it was an oil leak and he said it’s transmission fluid and he can’t help me with a tranny. So I took to the dealer and they said it’s not simple just to check the level,$ 300 bucks. Seems to be leaking on drivers side. I have an appt with a tranny shop in few days. I was really hoping to get a few more years out of the car for my daughter until she is done with college and can get her own car. I don’t mind paying for repairs, I just can’t put 3000-4000 bucks in this car to fix.
    The car runs really good.
  9. BiomedO1
    2,821
    1,499
    SacTown, Ca
    An ATF change should cost you around $125-$175. It takes 3.5 quarts of Toyota ATF WS. It's a simple drain and fill - DO NOT let them tell you need to flush it, that's a rip-off IMHO, because 98% of the ATF will drop out of that drain plug.
    Have whomever does the job, measure how much came out vs how much was put in. That's your leak rate. Do that again in a few months of normal driving activity to gauge the rate of loss. Place a piece of cardboard where the car is normally parked to get an idea of drip rate. If your losing more than 1.5 quarts every two months, it's needs fixing - otherwise you can just keep adding every couple of months. You may be able to keep the car for a few more years, depending on how fast it's dripping out of there.
    Good Luck.....
  10. MAX2
    MAX2 Senior Member
    1,436
    483
    101
    It is worth carefully examining the lower part of the transmission box.
    Any fluid leak should not be left unchecked.
    The fluid costs a small amount.
    Replacing or repairing the block in which it leaks will cost an order of magnitude more if the fluid suddenly disappears.
  11. Mel Crittenden
    Yuma AZ
    If the car is leaking transmission fluid through a seal of some kind, does anybody know what the cost is to usually repair it?
    I am inclined to get it fixed if it does not break the bank.
    With my teenage daughter driving the car, I don’t want her to have a problem and I can’t get to her quickly enough.
    I recently had replaced struts, breaks, rotors, and axles along with water pump, and valve stems for the tire pressure sensors. Those repairs were costly but it was done.
    Thank you for advice.
  12. Mel Crittenden
    Yuma AZ
    We quit driving the car until a transmission mechanic can have a look at it. I did not want to burn up the transmission due to low fluid level . That repair would be on a whole new level. lol
  13. pasadena_commut
    pasadena_commut Senior Member
    2,280
    679
    Southern California
    But not the leak rate. Many types of vehicle leaks are at different rates depending on how hot the car is, how fast it is going, and so forth.
    For a DIY solution, the OP could pull the fill plug, put in a tube from the top, then slowly add fluid until it overflows, keeping track of how much fluid went in. Then plug it up again. Repeat in a few days, then a week, or whatever they determine is a safe interval. That will give the leak rate with no need to drain it.
    The problem with that approach is that the problem seal might not just get slowly worse, it could fail catastrophically while driving. So best to find out what the actual problem is, as the OP is doing.
  14. Mel Crittenden
    Yuma AZ
    I will find out in a few days and im hoping for the best. I suppose that Toyota did not intend for the cars to last this long.
    I’m sure other people with a 2008 or older Prius must have had leaks at some point in the transmission. I just hope it’s a seal that can be fixed.
  15. BiomedO1
    2,821
    1,499
    SacTown, Ca
    Well if you lucky, whomever did the axle replacement may have nicked the transmission seals. Hopefully that's where it's leaking from. Cheap easy fix.
    Good Luck....
  16. Mel Crittenden
    Yuma AZ
    So I heard back from mechanic, the seal was loose to fill the transmission. He tightened it and then drive it a few times. No leak.
    I feel very fortunate it was not anything really bad.
    Mendel Leisk and BiomedO1 like this.
  17. BiomedO1
    2,821
    1,499
    SacTown, Ca
    That's strange, If the ATF was never changed - how did that fill plug get loose? From the factory, those plugs are so tight I've to use a 36+ inch breaker bar to get them loose.
    If this was the same mechanic that replaced the axles, he probably realized his mistake - while he was under there. A good mechanic would check ATF levels after replacing axles, since some ATF drips out. Then again, a 'good mechanic' wouldn't leave a loose fill plug either. But we're all human...... glad it worked out.
    YMMV.....
    #17 BiomedO1, Feb 13, 2025
  18. Mel Crittenden
    Yuma AZ
    The mechanic that changed the axles would not do anything with transmission so I took car to transmission shop. They cleaned up the car and drive around a few days and said that the only place they could find was that one bolt.
    mechanic did say that maybe the person that changed the axles did not clean up very well and it’s dripping because of that.
    now on to motor mounts lol.
