transmission magnetic drain plug
Discussion in 'Gen 2 Prius Main Forum' started by paycee, Aug 4, 2012.
  1. paycee
    paycee Junior Member
    48
    Does anyone use a transmission magnetic drain plug? If so, any idea where to buy one?
  2. paycee
    48
  3. Mike500
    Mike500 Senior Member
    2,593
    766
    Make your own.
  4. PriusCamper
    PriusCamper Senior Member
    12,064
    4,896
    Pacific Northwest, USA
  5. Britprius
    Britprius Senior Member
    5,194
    1,918
    Herefordshire England
    The Prius transmission already has a magnetic drain plug as standard equipment.
    PriusCamper likes this.
  6. Patrick Wong
    18,200
    6,493
    2G Prius is equipped with a small magnet on the tip of the transaxle ATF drain plug - so all 2G owners use a magnetic drain plug and therefore there is no need to buy one...
  7. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    At least Gen 1 and Gen 2 come stock with a magnetic drain plug. I can't confirm newer ones do, but why would they quit?
  8. Patrick Wong
    18,200
    6,493
    Classic has a small rectangular magnet which is located on the bottom of the steel transaxle drain pan. You will need to remove the drain pan and replace the gasket if you wish to access the magnet, which will look like a swollen black slug with all of the ferrous metal particles on it.
  9. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Cost. A small cost but all the small costs add up.
  10. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    Wouldn't paying for customers' transmissions also be a cost? Rarer, but not so small.
  11. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I think it's highly unlikely that would be an issue during the warranty period.
