Transmission oil change in 2gen - Does temperature matter?
Discussion in 'Gen 2 Prius Technical Discussion' started by LukUsc, Jun 14, 2020.
  1. LukUsc
    LukUsc Member
    69
    26
    Poland
    Quick question :)
    The oil is topped up until it is poured.
    And this is the only condition when changing oil?
    In 2gen are there any requirements regarding gearbox oil temperature when replacing?
    Like e.g. as in newer gears (with a pipe in a stopper). I don't see temperature comments anywhere, but I would like to make sure :)
    Thx!
  2. dolj
    dolj Senior Member
    8,553
    4,344
    Wellington, New Zealand
    I'm sorry Luk, but your post doesn't make a lot of sense. Maybe something is lost in translation.
    The only part I can guess at is about temperature. When changing the transaxle fluid with new Toyota ATF-WS, most of the posts are where the temperature is temperate so nobody is really thinking about temperature. So as long as it is warm enough to work without dressing for a snowstorm, it should be warm enough – 20 - 30ºC.
  3. Mendel Leisk
    41,882
    I think you mean when refilling add fluid till it overflows, starts coming back out?
    Yes, that will give correct level. Do have the car raised and level.
    Regarding temperature: if I recall correctly I've always done transaxle fluid change directly after drain and fill of the engine oil, and that was just after driving.
  4. LukUsc
    LukUsc Member
    69
    26
    Poland
    Indeed, the translator went crazy, Too many technical returns :)
    It was exactly to, what moment we were filling. Is the version - until it starts to pour out is correctly?
    Regarding temperature - most automatic gearboxes in the specification have a given oil level at a given oil temperature, e.g. at 30°C this condition, and at 70°C a different one. I saw that the new CVT gearboxes have a dedicated compensating tube in the drain hole. But, I did not find any information regarding oil temperature when changing for 2gen.
    Does it mean that the oil temperature during the oil change is not important in 2gen?
  5. dolj
    dolj Senior Member
    8,553
    4,344
    Yes, as long as the car is level.
    It would seem so. I do not recollect temperature ever being mentioned in the repair manual. The level of the transaxle is supposed to be regularly checked as part of some service intervals, and it never refers to any temperature requirement.
    LukUsc likes this.
  6. Mendel Leisk
    41,882
    I don't think the transaxle fluid temperature is important, at least there's no mention in the Toyota Repair Manual (if I recall correctly).
    2nd gen Repair Manual only describes level check. 3rd gen RM does describe full drain and fill,
    I'm only tapping on a phone right now, I'll post RM excerpts in a bit. It's pretty straightforward, but interesting to see what they say.
    Toyota's gotten increasingly adamant about only using fluid from freshly opened bottles by the way. I think they really want to limit its exposure to atmosphere, absorption of moisture maybe.
    (See I'm echoing a lot of what @dolj already said.)
    LukUsc likes this.
  7. Mendel Leisk
    41,882
    2nd gen (level check only), 3rd and 4th gen drain-and-fill:
    LukUsc likes this.
  8. Aegean
    Aegean Active Member
    464
    208
    Alexandria VA
    Temperatures are important for other transaxles like Audi’s and VWs where the level check is done by a plug under a level car, while the engine is running, fluid is warming and testing with an OBD reader.
    The Prius has no temperature requirement and it is done with car turned off. The easiest transaxle refill method I have ever done!
  9. LukUsc
    LukUsc Member
    69
    26
    Poland
    New Toyota automatic transmissions, e.g. in Corolla, have temperature recommendations. Also the next new Priuses may also receive them. ;)
  10. LukUsc
    LukUsc Member
    69
    26
    Poland
    Thank You all for explaining the topic of gearbox temperature in 2gen! ;)
    Fern1461 and Mendel Leisk like this.
