Transmission revving up hill
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Invisible Eddie, Dec 3, 2015.
  1. Invisible Eddie
    Invisible Eddie New Member
    Santa cruz
    2015 Prius c
    I just got a used 2015 with only 1000 miles on it from the dealership. Everything is great except I notice when going up and over the mountain highway I take everyday to work the car revs kind of loud and feels like there's not a lot of power. I don't know if this is normal or not, but it doesn't sound right to me. Any thoughts? Thanks
    49,504
    welcome! normal. it's the tranny type. and coming down, your engine might run to burn off excess charge.
    if you are concerned, take a new one for a test drive.
    #2 bisco, Dec 3, 2015
  3. Mendel Leisk
    38,732
    See if a dealership has a Prius c loaner or demo they could let you test drive on the same stretch of hill, maybe with a mechanic along, see if it sounds the same? Or at least just take yours up a hill with the mechanic along?
  4. Invisible Eddie
    Santa cruz
    2015 Prius c
    Thanks
    Thanks
    #4 Invisible Eddie, Dec 3, 2015
  5. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    There are at least a couple of reasons why the Prius C's engine sounds often seem strange to new drivers:
    1) The drivetrain uses a continuously variable transmission, so it doesn't have to step through "gears" while accelerating like a conventional drivetrain does. If you're not demanding excessive acceleration then the engine will usually run at a constant speed even though the car itself is speeding up.
    2) The engine not only powers the drive wheels but can also apply power to the motor/generators to recharge the battery. In cases where the car decides that the traction battery needs recharging the power demand on the engine may increase or decrease even though no changes have been commanded by the driver. Thus, you may hear the engine RPMs going up or down even though you haven't done anything to cause it.
    In terms of power, the C is optimized for getting great mileage while driving in the city. The engine likes to run in a narrow RPM range with modest power output and be supplemented by the battery when more power is needed in order to optimize efficiency. It has the power to climb hills, but you will probably have to depress the accelerator pedal further than you're used to and it can get pretty loud to let you know how hard it's working.
