Transparent oil?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Johnsmith009, Feb 4, 2019.
  1. Johnsmith009
    Johnsmith009 Member
    124
    34
    Mississauga, Ontario, Canada
    One noob question after the other I suppose.
    Just before I went home for the day, I went to a gas station nearby, fueled up, checked oil and the sight of my once dark amber dipstick being silvery metal instead shocked me. "Could this be the oil burning problem? I've driven 200km and it was full then!" Upon closer inspection, there is a thin film covering it, and I DID do a full maintenance at a dealership on Friday. I know the answer is probably "yes", but Google doesn't help much and I want to be sure I'm not driving without oil:
    Can oil be transparent?
    49,694
    Yes
    It’s a frustrating task trying to read the level.
    Wipe it, re dip it, and look for the side without a streak
    qettyz likes this.
  3. Johnsmith009
    Johnsmith009 Member
    124
    34
    49,694
  5. Mendel Leisk
    38,875
    On level ground, pull the dipstick and wipe, then wait five minutes, say check your tire pressures, clean windshield to kill time. Then reinsert and pull out dipstick and check, it should be easier to read.
    The dipstick tends to draw oil up the tube when you pull it out. Then when you quickly reinsert, you get that smeared half-way up the dipstick appearance, hard to read.
    I agree too about flipping it over: usually the underside's a bit easier to read.
    fuzzy1 and bisco like this.
  6. Johnsmith009
    Johnsmith009 Member
    124
    34
    By easier to read, do you mean to see where the oil ends on the dipstick? Because I can see that fine, it's just the color I was concerned about. (It's just above two "dots", I WILL admit I never learned the units...)
    Mendel Leisk and bisco like this.
  7. bisco
    49,694
    the lighter the better(y)
  8. Grit
    Grit Senior Member
    6,152
    4,061
    Wilkes Land
    Burning oil is when the oil level dipstick measures less oil than the last oil level.
    Oil can also evaporate causing the oil level to dip lower.
  9. Johnsmith009
    Johnsmith009 Member
    124
    34
    I know, but my worry was ALL of it somehow evaporated.
    Foolish I suppose, but I've never seen clear oil.
  10. bisco
    49,694
    funny thing, but when you drain it, it's light brown
  11. Grit
    Grit Senior Member
    6,152
    4,061
    Wilkes Land
    No worries. Feel free to steal my method; get a lint free napkin, and place one side of dipstick on the napkin. Move the dipstick aside3 parallel to the oil that's soaked onto the napkin, where the oil stop soaking is where the oil level is.
  12. MichaelKnight
    MichaelKnight Junior Member
    39
    22
    Westcoast
    Above members have replied and given you the answer...
    Mobil suggested...
    "We recommend checking the oil level either before turning on the engine or 5 to 10 minutes after shutting down so you can have all the oil in the oil pan to get an accurate measurement".
    But always return to the manufacturers OM....
    This wasn't my time/era...But it would be nice to have attendants
    benagi likes this.
  13. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,476
    1,552
    Bay Area
    Man, your engine bay needs a good wash :ROFLMAO::ROFLMAO::ROFLMAO:
  14. Grit
    Grit Senior Member
    6,152
    4,061
    Wilkes Land
    Watch a lot of people jump in and say different :p
    Raytheeagle likes this.
  15. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    Not the worst one I’ve seen;).
    But I’m no saint either:oops:.
    Dirt is character (y).
    NutzAboutBolts likes this.
  16. Johnsmith009
    Johnsmith009 Member
    124
    34
    I'd love to. But not sure how. Any Prius specific guides so I don't fry/break it? Also given I don't really have any place near my house, it'd have to be somewhere else I guess. Maybe water from a self-serve car wash hose? They're pretty pressurised though.
  17. NutzAboutBolts
    1,476
    1,552
    Bay Area
    Purple power and garden hose. We did a video for my Prius (y)
    MichaelKnight likes this.
  18. douglasjre
    douglasjre Senior Member
    1,901
    661
    Orlando, FL
    My oil is cleaner than that bc I drain it cold when all the oil is in the pan. I get 5.5 quarts out that way.
  19. TMR-JWAP
    TMR-JWAP Senior Member
    6,330
    6,006
    Columbia, SC
    You have a bonus size oil pan?
  20. Johnsmith009
    Johnsmith009 Member
    124
    34
    Thanks! But seriously, I don't need to cover ANYTHING in a stock 2010? The fuse box, for instance, doesn't seem watertight at all.
