Trasmission
Discussion in 'Prius v Technical Discussion' started by Glenninmb, May 16, 2023.
  1. Glenninmb
    Glenninmb Junior Member
    16
    Hello i am looking at R@R ing the transmission on my 2012 prius V. A local shop mentioned that they would have to program the new transmission has anyone else heard of this? Thanks in advance!!
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,974
    4,716
    Texas Hill Country
    No. The transaxle is controlled and powered by the inverter and other ecus, none of which are in the transaxle.
    What seems to be wrong with it? Many misdiagnose a transaxle when it really is an intermittent misfire which causes a lack of sync at the transaxle's damper.
    #2 rjparker, May 16, 2023
    49,488
    how much do they want to program it?
  4. Glenninmb
    16
    Thank you for the reply, the issue is a high pitched whine and the passenger side cv axle can be moved up and down by hand while fully inserted into trans axle. When i popped it out there is metal fused to the axle from somewhere inside. Personaly i think the shop did not want to work on a hybrid so they used the " gotta be programed" excuse to not work on it. And no the whine is not comming from either wheel bearing already had it checked.
  5. Glenninmb
    16
    As soon as they said it needs to be programed he followed up with " and that's something we do not want to do" I knew they were not interested. So the price was never discussed.
  6. bisco
    49,488
    might be easier to replace it with a low mile salvage
    Tim Jones likes this.
  7. Tim Jones
    Tim Jones Senior Member
    1,706
    553
    SE Texas
    2011 Nissan LEAF
    Get used... they are low cost... shop around. Make sure it comes from a v !!!!!!!!!!!!!!!!!
    You can tell cause the v trani is water cooled.
    I know cause mine went bad.......
  8. ChapmanF
    15,614
    The liftback and v transmissions are both water cooled, in the green area shown.
    The v transmission also circulates water in the purple area. (The liftback transmission is the same case, just missing the plate and hose connections over that area.)
  9. Tim Jones
    1,706
    553
    SE Texas
    2011 Nissan LEAF
    I think they might be geared differently......................
  10. Mendel Leisk
    38,726
    I believe so, but it’s external differences that’ll help in verifying its a v transaxle.
  11. ChapmanF
    15,614
    Yes, the final drive ratios are different.
  12. Raphael Muscarelle
    Raphael Muscarelle Active Member
    661
    222
    Cape Canaveral Floridia
    If it's the same as the 2011 gen 3 Prius transmission.
    Nope no programming needed.
    Do not use a junkyard transmission as most junkyards don't know how to store a hybrid transmission.
    I just put one in my 2011 Prius gen3
  13. Raphael Muscarelle
    661
    222
    I went to 4 different salvage yards replacing my transmission. All of them left the driveshaft holes open or broke the vent letting in atmosphere.
    I strongly suggest NOT putting in a salvaged transmission.
  14. Tim Jones
    1,706
    553
    SE Texas
    2011 Nissan LEAF
    So where do you get one then?
    The Hatchback and the v are different plumbing and gear ratio.
