Tread wear
Discussion in 'Gen 3 Prius Main Forum' started by hadone, Feb 15, 2013.
  1. hadone
    hadone Junior Member
    Iowa
    How many miles should I expect to get out of a set of original tires. I have 33000 miles. Defenders have a $75.00 rebate now. Does it make sense to buy now and save the rebate money or wait.
  2. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    30k-50k is the average for a set of the OE Yokohama AVID S33D.
    If you do not drive more than 15k a year I would suggest getting the Energy Saver A/S over the Defender. You'll get much better fuel economy. The Defender will last longer but if you don't drive enough then the tires will dry out long before they wear out. Dry tires are not safe tires.
    The rebate is $70 on Michelin tires.
  3. JimboPalmer
    12,470
    6,863
    Greenwood MS USA
    If it was me I would change tires in the fall, the heat of summer would happen to the old tires and the great tread depth would be there for winter.
  4. BZzap!
    BZzap! Senior Member
    1,607
    877
    IMO, tire age is a huge consideration for tire replacement. Coupled with tire wear, it's of coarse, a no brainier. If the tires are more than 3 years old with moderate tire wear, replace them. You can also take advantage of good sale pricing at the same time.
  5. NASCAR Mike
    NASCAR Mike Senior Member
    83
    Richmond VA
    My Yokohamas lasted about 33k miles. They should have lasted at least 40k.
    I bought the Michelin Enegy Saver A/S tires. Best decision I ever made for my Prius. Not only does the car handle better, it has less road noise and I gained 1.8MPG with the new tires.
    I have over 12k miles on the tires and they are great. Barely any treadwear. I expect to get at least 60k miles out of these tires.
  6. retired4999
    2,652
    625
    Eau Claire, Wi.
    Its just me but I always by in the fall for the best winter driving. Just start looking early fall so you have some time to get a rebate before snow fall or ice. :)
