Treo 650 almost works
Discussion in 'Gen 2 Prius Audio and Electronics' started by toddpalino, Aug 10, 2006.
  1. toddpalino
    toddpalino New Member
    Shepherdstown, WV
    I have a 05 and I've been trying for some time to get my Treo 650 connected up correctly. I've read through just about all the suggestions I can find here, I'm running the latest (1.20) firmware on the phone, and I've trying pairing many many times. Right now the phone and car paired correctly (I didn't have to do the "make a phone call" trick to get it to complete). I can receive calls through the car without a problem, as I found out this morning when my wife called on the way to work. But I can't initiate calls from the car. If I try, everything is silent and the phone does not appear to be dialing.
    Anyone have any suggestions as to what to try next?
    -Todd
  2. jrfaris
    jrfaris Member
    352
    Windward Oahu
    <div class='quotetop'>QUOTE(toddpalino @ Aug 10 2006, 08:14 AM) [snapback]300819[/snapback]</div>
    We have 2 Sprint 650s that work fine. The only thing I can think of is that there might be a problem with cell coverage. Can you dial and connect to a call from the Treo? If so, does it connect to the Prius when you dial? The call should automatically transfer to the Prius car kit .
  3. Actual Mileage
    153
    Portland. Maine
    <div class='quotetop'>QUOTE(jrfaris @ Aug 10 2006, 02:04 PM) [snapback]300942[/snapback]</div>
    Sorry for stupidity of following question - I have base audio - no NAV, no Bluetooth. Is there an aftermarket add-on for the Bluetooth? I also have Verizon 650.
  4. got_prius?
    got_prius? New Member
    Denver, CO
    <div class='quotetop'>QUOTE(Actual Mileage @ Aug 16 2006, 09:47 AM) [snapback]304115[/snapback]</div>
    I have read that Verizon cripples the Bluetooth capability on their phones. Have you looked into that?
  5. tleonhar
    tleonhar Senior Member
    1,541
    34
    Belle Plaine, MN
    <div class='quotetop'>QUOTE(Actual Mileage @ Aug 16 2006, 10:47 AM) [snapback]304115[/snapback]</div>
    Yes there is, I have the Parrot CK3100 and it is awsome! http://www.parrot.biz/usa/products/index.php?id=ck3100 Install went quite well, and everything works as advertised, plus you get voice activated dialing as well. I have a Treo 650 as well allthough it's an unlocked GSM (will work with T-Mobil or Cingular).
  6. pfile
    pfile Member
    319
    35
    bay area, ca
    <div class='quotetop'>QUOTE(got_prius? @ Aug 21 2006, 02:09 PM) [snapback]307052[/snapback]</div>
    my boss has an 06 prius and a verizon 650 and he has problems with bluetooth. it won't stay paired and i think he has to initiate a phone call while its trying to pair to get it to link up. and then it drops the link after the call is ended.
    i have a sprint 650 and never had any problems with my 06.
    its possible he needs a firmware update, but i'm 90% sure he is up-to-date.
  7. berylrb
    berylrb Member
    308
    san francisco?
    hey todd,
    do you have a bluetooth headset, is it off?
