Triangle exclamation mark light/beep over speed bumps?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PAULAD, Jun 14, 2022.
  1. PAULAD
    PAULAD New Member
    TN
    I have a 12 yrs old prius with brake, abs, and skid lights on. So I undo the reset tire button under the steering wheel to get a clear path to the diagnostic cable port to use the safety pin method. I lost the screws, but it seems ok clipped in without them. I recently got new tires. Never knew of this button before so I push it. Right when I go over the large speed bumps at the dealership who is about to test drive for a trade in value, the triangle exclamation mark lower left corner flashes and beeps a couple times. It goes away after about 10 seconds or if I turn off the car and restart it. So this is what is lowering the trade in amount. Anyone know what may be going on?
    51,155
    the triangle means there are trouble codes to be read that will lead you along the correct path for diagnosis and repair.
  3. Eddie25
    Eddie25 Active Member
    490
    207
    MI
    The wheel speed sensor wires are SUPER sensitive to being routed weirdly, and those can cause the abs, skid, and brake lights to come on. Since you just got tires I would consider that a possibility. I don't think that explains the going over bumps situation, but I thought I'd throw that out there.
