Triangle of Death, Brake light, all warning lights, no codes
Discussion in 'Gen 2 Prius Main Forum' started by BrokenWrench, Aug 8, 2023.
  1. BrokenWrench
    BrokenWrench Junior Member
    56
    Tampa, FL
    My 2007 Prius won't go into gear - it will go into park and neutral only, it also has the Triangle of Death, Brake light, all warning lights, but no codes showing.
    Any thoughts?
    Thanks
  2. PriusCamper
    PriusCamper Senior Member
    11,061
    4,502
    Pacific Northwest, USA
    That's what the car does to protect itself from you ignoring the warning lights and continuing to do more driving, which will likely cause more damage.
    If no codes are showing it's probably because your code reader isn't handling hybrid specific error codes.
    What app or software and hardware are you using?
  3. BrokenWrench
    56
    Tampa, FL
    I use two Apps - I run Dr. Prius all the time when driving and it still shows all 28 modules as working.
    I also use Torque which has always shown a code in the past when there is a problem but nothing on it now.
    The issue happened at start-up in the driveway and I've not been driving with any warning lights on.
    I did unhook the 12 volt but that did not reset anything and the issue is still there.
  4. PriusCamper
    11,061
    4,502
    Try car scanner app... It will tell you more than others. And if that doesn't give you anything Toyota Techstream will.
    Also it's not recommended to always have your OBD2 plugged in. There's discussions on here about people who've done that who have had it screw up their car when the OBD2 glitched out. I suspect because most OBD2 run a bit hot that over time that heat causes it to fail.
  5. BrokenWrench
    56
    Tampa, FL
    The car "Self Cured" for the moment - odd, but I'll take it for now.
    Prius Camper, I'm glad to see you are still on here and hope all is well!
    PriusCamper likes this.
  6. mr_guy_mann
    mr_guy_mann Senior Member
    3,431
    1,485
    NJ-USA
    Torque and Dr Prius are useful apps but both are very limited in what they can do. You might consider getting a more capable scantool (whatever happened hasn't "fixed itself" - it will likely reoccur.)
    Here's a thread that reviews several scantool apps and devices. Several are capable of scanning for codes and data in all systems of a Gen2 Prius.
    https://priuschat.com/index.php?posts/3290690
  7. PriusCamper
    11,061
    4,502
    Was helping someone out today and couldn't get error codes with Dr. Prius so again installed "Car Scanner App Elm" and watched it scan and was yet again very impressed with how thorough that app is... The way it displays what it's scanning while its working is very comforting if you want to leave no stone unturned. That being said, Toyota Techstream on an old Windows computer via a pirated mini-VCI dongle & software for $35 is the last and final option.
  8. mr_guy_mann
    3,431
    1,485
    NJ-USA
    Car Scanner is a decent app - for a Gen 3 or Gen4. On a Gen2 it can only get some codes and data for ECM, hybrid control, and HV battery ecu's.
    If you spend a "little" more money you can get lots more functionality.
    Yes, Techstream is still "the best", but I don't keep a laptop in the glovebox.
