Triangle of Death Code P3191P, P0A0F/205 and C1310/156
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by JbMech, Oct 10, 2022.
  1. JbMech
    JbMech New Member
    Washington
    I recently have code P3191, P0A0F/205 and C1310/156 on 2005 Prius with 202K miles. The list below is what is complete.
    1) 12v battery new. Measure 13v
    2) Hybrid battery new refurbished. Measure 15v on each pair. State of charge more than 50%. I use Prolong to charge when it needs.
    3) Fuel tank new. With 3/4 fuel in the tank. Fuel pressure check at 44-48 psi.
    4) New MAF from Oreilly, P/N MF4226N, Blue Streak. Ordering the new Denso to try out. It is on its way.
    5) Throttle body new.
    6) PCV valve new.
    7) Engine coolant temperature new.
    8) Crankshaft position sensor check within the spec 985-1600 ohm at cold.
    9) Camshaft position sensor new.
    10) ECM new.
    11) Ignitions are new.
    12) Spark plugs are new.
    13) Catalic converter old from the junk yard. Install it with pipe clamps.
    14) Inverter pump is working. I see the fluid movement and the pump runs when test.
    All of these was done, however the ICE still not turn over. I read the other thread that point out the intake manifold has a crack. I will remove, clean and inspect the intake manifold this weekend.
    It is my parent car and they are the first owner. It was running fine until it was sitting for 6 months due to catalic stolen.
    The car was running for 3 months after the fuel tank and catalic replacement with 2 incidents of losing its power on the highway. Stop for 5 minutes and started again, be able to get home and clear the code P3191, P0A0F/204. This third time, it get towed. The ICE turn only by battery.
    Please help. Attachment is the report from Techstream. I don know what else I could do. Really want to fix this car.
  2. JbMech
    JbMech New Member
    Washington
    Removed and inspected intake manifold. Replaced the MAF with OEM Toyota part. Still no start.
  3. JbMech
    JbMech New Member
    Washington
    Spark test and compression test is also good.
  4. tbert
    tbert Junior Member
    27
    I am going through this right now, also. Car sat around 6 months while we worked on the body. Greenbean replacement traction battery, I have a Maxxflow to keep it charged. New Denso MAF, cleaned the throttle body,new igniters and spark plugs, oil change, fresh fuel. Still won't start. Ready to scrap it.
    Did you actually solve the issue with your car?
  5. mr_guy_mann
    mr_guy_mann Senior Member
    4,098
    2,001
    NJ-USA
    Does the fuel pump work? What's the fuel pressure? Do the injectors "fire"? What does the scantool show for MAF readings while it spins? Do the coils produce sparks? Any codes?
    Brian1954 likes this.
  6. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    Third planet from the Sun
    There are two things to pay attention to.
    1. The engine speed does not reach normal values of about 1000 rpm and is 850.
    The speed is created by the motor-generator and the high-voltage battery in combination.
    2. The short fuel trim exceeds reasonable limits. Short FT B1S1 -21%
    Problems with extreme fuel trims make it impossible for the fuel system to work, either too little fuel and it does not burn, or too much and it does not burn.
    It is necessary to reset the accumulated values by disconnecting the auxiliary 12V battery for one minute.
