Triangle of death stumps the dealer!!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by MisterMan, Jun 15, 2012.
  1. MisterMan
    MisterMan New Member
    So Cal
    Hey techies, I just wanted to let you all know about a situation that I had with my 2004 Prius. First of all, let me tell you about my wife's car. 2004, 260,000 miles and looks like it was ridden hard and hung up wet! Anyways,... since we owned the car from new the maintenance has been kept up and the only things that has been major was replacing the AC compressor & I put in a new used (2009) set of batteries over a year ago. Anyways,... the triangle light of death came on and the ready light would not turn on so I couldn't put in in any gear. I put my scanner on it to check the codes and their were none but when I selected to clear the codes, the light turned off. After that I could put in in gear. After about 2 minutes, the light came back on again. To save a diagnostic fee from the dealer, I replaced the 12V battery and still had the same problem. I decided to take it to the dealer and they told me that I had a short in the transmission. I didn't even ask for an estimate! I did ask what years were compatible with my Gen II and they said up till 2009. I got a tranny from the same place I got my batteries from and it was from a 2008 with 36,000 miles. The Toyota Tech did say that a lot of the times when there is a short in the tranny, the Inverter might have had to work over time and it might be bad too. They didn't have any way to figure out exactly which one it was. Anyways,... 6 Hours of labor and $450 for the tranny, I finished the job. I started it up and the light came on again. I cleared everything and then drove it and as long as the engine was running, the light would stay off but as soon as I sat still for about 2 minutes, there it is again. I took it back to the dealer and this time there was no charge for the diagnostic but the same code came up again. (I'm sorry but I don't know the code #. I can ask) As I was warned before, I went back and picked up a 2008 inverter from the same car as the Tranny and that only took about 30 min to R&R and after another $400, I was finished. Yahoo!!! so I thought. After about 2 min, the light came back on. At this point, I now have some gas cans in the car and a road flair just in case I need to torch the poor thing. I went back to the dealer and by now the Tech feels like crap because on his recommendation, I have now put about $1000 into this POS and it still isn't working. I told him, (polity) please trouble shoot the car and be sure of what you find. He had it for over a week and he would call me every day with an update that he is still looking at it with other techs from another dealership. (by now even I told him of the gas and flair in the back) Anyways,... He called me and told me to come over. it didn't sound good. I went there and he told me with the service writer in front of us... he can't figure it out, Sorry dude. After the service writer left he called me back and showed me my problem. One side of my high voltage cables on the HV Batteries were chard from either a bad connection or something. I checked the cable and it was tight so I installed it ok when I replaced the batteries so we decided that it was from the tranny being shorted out. I asked him why did he tell me in front of the Service writer that he didn't figure it out? The reason why he told me that was so then the dealer couldn't charge me for the many hours of his diagnostic time. I later replaced the cables and that was a pain in the nice person just for that but now she is running good. I even poured the extra gas in the tank!
    So after all this, if someone has a similar problem, check the battery connections on the HV batteries. JUST BE CAREFUL.
    northwichita and ericw28 like this.
  2. cnschult
    cnschult Active Member
    772
    96
    Michigan
    I do feel that this is one area that makes a honda IMA hybrid better to own then a toyota system as in a honda if there is a problem with the batteries or hybrid system the car can still function as a normal car. And as you are well unfortunately aware if anything goes wrong with the toyota hybrid system the car becomes a big heavy paper weight.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Holy lack of paragraphs, Batman! I won't even attempt to read a monolithic post like that. Perhaps the OP will consent to edit that beast into a more manageable form.
    Tom
  4. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    Interesting story. I wonder if there are DTCs for damaged HV battery cable? Is the transaxle not isolated from the battery (with the inverter in between)? Is there any over-current protection in the inverter?
  5. Patrick Wong
    18,200
    6,471
    My guess is that an over-current situation causing damage to the battery cable would more likely be an inverter fault instead of a transaxle fault.
    In any event, now that the traction battery, transaxle, and inverter has been replaced, the OP only needs to replace the engine, for a complete powertrain swap to be done... :D
    2009Prius likes this.
  6. Flying White Dutchman
    4,374
    313
    o maybe itswas just the cablin
    omg you did a hell of a job replacinall of that.
  7. Rebound
    Rebound Senior Member
    3,964
    2,612
    Portland, OR
    Login to Facebook and Friend the Luscious Garage. They post photos showing how they troubleshoot problems like yours.
  8. Flying White Dutchman
    4,374
    313
    Only non facebook?
    They also have s website... There is more to internet than Facebook.....
    -Htc Tapatalk
  9. ahmeow
    ahmeow Prius Lover
    366
    70
    North CA
    For replacing the HV battery, Patrick did reminded us to double check the connnector/switch next to the battery. Problem exists when the connector is not plug good. Now the OP learn an expensive lesson. Thanks for him to share his painful experience with us. We should pay more attention when replacing the HV battery. Thank you.
    BTW, as Patrick suggested, since the engine is at it's 260000 mile life,chang another 'new' one. Not a bad idea. Then your baby will last forever.
  10. Mendel Leisk
    38,641
    Same here. It's an undigestible tome: condense and break into maneagable paragraphs please.
  11. brick
    brick Active Member
    1,083
    78
    Upstate NY
    MisterMan - Thanks for posting. Sounds like that was a PITA to diagnose but at least you came away with a basically new drivetrain for a grand. Not bad if you plan to keep on driving it.
  12. Rebound
    3,964
    2,612
    Portland, OR
    Luscious has a website, but if you want to see the repairs they've done to cars with problems like these, you should check out their Facebook page.
  13. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Congrats on now having essentially a new GenII! The cable is more of a symptom then a problem. What the problem is, we don't know since you elected to do the "replace whatever I can until it goes away" method of engineering. But hopefully one of the many parts replaced was the trouble area and now it is all ok. Also keep in mind that rodents and the like to chew on cables. Perhaps they like the colour of high voltage orange cabling more so then the surrounding cables?! :)
    Glad it is working again and with all the new parts for such a low price, you should be good to go for another quarter million miles.
