Triangular front windows?
Discussion in 'Gen 2 Prius Main Forum' started by Ducati Guy, Jul 24, 2017.
  1. Ducati Guy
    Ducati Guy New Member
    South Salem NY
    Anyone know what the purpose of the small triangular front windows is? Does not seem it is for visibility.
  2. WilDavis
    WilDavis Senior Member
    2,492
    2,153
    49
    To let the light in! …at least the ones in my 2009 Gen II do exactly that! …and both of mine are quite visible if you know where to look (I think it is called the "A" pillar)
  3. Tideland Prius
    16,154
    I think it's mostly style (the theme for the Gen 2 was "Triangular monoform"). If you look at the window frame from A pillar to C pillar and around the window sill, it forms a triangle.
    It can be useful if you're making a corner. I do remember a few times when we still had our Gen 2 that I'd use the small window to see the curb.
    Otherwise, I use it to put a parking pass (hides it from the normal windshield position but it can still barely get read by the scanner).
  4. dolj
    dolj Senior Member
    7,652
    3,866
    Wellington, New Zealand
    Exactly this.
    There is one (sharp) corner on entry to an access way I drive where the visibility it provides is invaluable.
  5. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
    Great place to stick the suction cup on my phone holder. :D
