Trick NAV unit into showing reverse camera while giong forward
Discussion in 'Gen 3 Prius Audio and Electronics' started by adrianblack, Jan 9, 2010.
  1. adrianblack
    adrianblack Member
    447
    187
    Los Angeles
    Has anyone tried to trick the navigation head unit into showing the reverse camera while going forward? I would love to have a button to engage this at any time.
    Connector L42 pin 5 is the signal that tells the nav unit the car is in reverse. The service manual says it is "used to help determine position" ... Hmmm.
    It would be possible to put a switch in line with the camera as well to input another video source like a DVD player. (Use AUX in for the sound.)
  2. adrianblack
    adrianblack Member
    447
    187
    Los Angeles
    Oh ya, according to the manual, sending 12v to this pin will tell the unit you are in reverse.
  3. HollywoodHybrid
    HollywoodHybrid New Member
    Los Angeles
    Possible tip: The rear camera also appears on the screen when the Advance Parking Assist is engaged for parallel or back-in mode parking.
  4. Paradox
    29,110
    8,590
    201
    2014 Prius v wagon
  5. elmo2274
    elmo2274 New Member
    23
    Raleigh NC
