Trim Panel under glove box
Discussion in 'Gen 3 Prius Main Forum' started by MOJIZ QUAZILBASH, Sep 16, 2018.
  1. MOJIZ QUAZILBASH
    MOJIZ QUAZILBASH Junior Member
    Tulsa, oklahoma
    Hello everyone,
    Just bought a 2010 Prius and was doing some maintenance on it and found the trim under the glove box was missing, exposing the wiring and such. Can someone tell me the part number so i can order it. Thank you.
    51,141
    congrats and welcome.
    if no one here has the answer, stop in at a local parts dept and ask.
    all the best!(y)
  3. Mendel Leisk
    40,575
  4. Mendel Leisk
    40,575
    McGeorge Toyota site appears to be down now btw, just momentarily? But you can search that part number. Per @bisco, I would check local dealership first.
  5. MOJIZ QUAZILBASH
    Tulsa, oklahoma
    That's the part... Thanks. I went to the dealer for wiper arm but and they ordered the wrong part so this time wanted to post here before I ordered from them.
  6. bbjonz
    bbjonz Junior Member
    Arizona
    Sorry to revive a zombie thread but how do you put the under cover back on? Ours fell off but seems otherwise intact but couldn't figure out how to put it back on. Thanks in advanced.
  7. Brenden Truman
    Brenden Truman Junior Member
    Fort Worth, Texas
    Also wondering this. I spent way too much time trying to put it back on and can't keep it secured.
  8. ChapmanF
    17,326
    It has a tab that slips into a plastic socket near the firewall, and tabs at the rear edge that clip up to the instrument panel. If any kind of work has changed the dimensions between those points, it might not stay very secure.
  9. bbjonz
    Arizona
    Thanks! I had a moment of clarity and realized that it had fallen out backwards, so that the single clip was pointing toward the rear of the car. Once I figured that out, the rest was exactly as you described.
