Trim Rings on 2006
Discussion in 'Gen 2 Prius Main Forum' started by Walker1, Feb 18, 2006.
  1. Walker1
    Walker1 Empire
    911
    FL
    I was wondering what the aluminum alloy rims on my 2006 looked like without the trim rings.
    What an unbelieveable difference! The wheels went from looking cheap & cheesy to very sharp mag wheels. I can't believe Toyota used those cheap pieces of junk on an alloy rim to begin with.
    Now the Prius has a whole other look. I never liked plastic relating to wheels.
  2. mehrenst
    mehrenst Member
    439
    San Jose, CA
    The "trim rings' are there to assist the flow of air around and past the wheel well.
  3. Jack Kelly
    Jack Kelly New Member
    1,434
    Tom (isn't it?), did you learn this somewhere via Toyota information, or do you just surmise it? I've seen it posted before, but with no backup.
    I also have a hard time believing it. :huh:
  4. Jack Kelly
    1,434
    In any case, Walker, yes, hundreds of thousands of ill-conceived trim rings should now be collected and melted down to make, uh---what COULD we make, other then a giant gray plastic blob?
  5. flareak
    flareak Fleet Captain
    1,016
    St Louis, MO
    we could make sharon valerii cylons
  6. mehrenst
    mehrenst Member
    439
    San Jose, CA
    Yes, but I don't remember where it was. I know that there is a lot about airflow on the Prius that isn't really obvious. I was driving through some farming country in the evening and when I got home there were all these little black spots from about 6" ahead of the antenna down to the top of the hatch window. (My Prius is white so they were pretty obvious.) They wipped right off and when I looked closely they were small flies. It kind of woke me up to one of the reasons for the shape of the Prius.
    It just makes sense if you look at the front of the car. Air will be compressed as it flows around the bumper and then it would get sucked into the front wheelwell and cause drag because it couldn't flow out the back of the wheelwell and would need to be compressed under the car. I think the issue with the rear wheelwell is more of a flow of air compressed under the car and up along the side panels. Once the air is moving towards the rear you want to minimize the disturbance of that laminar air flow. Removing the trim rings would encourage the air to suck into the wheelwell and cause additional drag.
  7. Kathleen2
    Kathleen2 New Member
    77
    Than should I remove the mud flaps that I recently installed?
    Kathleen
  8. mehrenst
    mehrenst Member
    439
    San Jose, CA
    Ah yes. Asuming they are "ill-conceived". :p
    However, in some cases the trim rings serve an important purpose. Some cars use the design of the wheel rings to pull heat away from the disk brakes. I read on another forum where a guy was rotating his tires and got the trim rings on the wrong sides which resulted in the rotors warping. He thought they were suppose to scoop air into the brakes while they were really designed to create a small vacum to suck the hot air out of the brake area. BTW, this was a production car and not something designed just for competition.
    IMO, Toyota uses the trim rings to reduce the drag of the wheelwells.
  9. mehrenst
    mehrenst Member
    439
    San Jose, CA
    I don't have the mud flaps. I just wash my car one a week so they're not an issue for me.
  10. jdjeep98
    jdjeep98 New Member
    211
    Wilmington, DE
    Hmmm... I took mine off because I like the way the wheels look without them, but if they help keep the drag down, maybe I'll put them back on.
    I knew I should have bought those racing disk moon covers... :lol:
  11. Hallowday
    Hallowday New Member
    46
    Indianapolis, IN
    Found this out in Google land.
    "I noticed that the alloy wheels have a suspicious looking plastic wheel cover on the outer rim. This easily pops off using the provided tire tool to reveal a nice sporty 6 spoke rim, similar to that of the RAV4. After about a week without the covers, I noticed a drop of 3-4 MPG, which I can only assume is related to the poor aerodynamics of the alloy wheel. Seems the folks at Toyota bought a few more MPGs by adding the plastic covers after a few wind tunnel tests found disturbance around the alloys. (Stick with the wheel covers)"
    Nothing definitive but....
    Here's the link:
    http://greendeed.com/
  12. Salsawonder
    Salsawonder New Member
    1,897
    47
    La Mesa California
    Took mine off sometime ago and have not seen any noticeable drop in mileage. Really like the look better.
    It is a beautiful day in SD!!! Time to get the dog in the car and go someplace!
  13. darelldd
    6,059
    389
    Northern CA
    I do understand what you're saying here. And let me add that there is NOTHING even approaching "laminar" flow in and around those wheel wells. Well... nothing on the whole car, but ESPECAILLY around the wheel wells. With the spinning tire/wheel, and the gaping hole of the well itself, the air is so mixed up in there that I'd have great difficulty in believing that something like the wheel trim ring could change the drag of the entire vehilce system in any meaningful way. A case could almost be made for smooth hub caps, or even skirts. But without full wind-tunnel testing, all we can do is guess. I have yet to hear of any wheel treatment short of a skirt that can significantly change the cd of a full-size vehicle.
    ** But I've been wrong before!
  14. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    This subject has been debated since the beginning of Pruischat and it boils down to a matter of personal preference. There is no evidence that the trim rings were provided for anything but looks. I think the wheels look better without them.
  15. jdjeep98
    jdjeep98 New Member
    211
    Wilmington, DE
    Well, based on this thread, I just popped mine back on for a while. I am driving up to New Hampshire for a few weeks for business. Hopefully, I will be able to determine whether or not they make any difference.
    Visually, I prefer the wheels without the rings, but if they get me a few miles more from each gallon, I'll go with form over function anytime. ;) [edit] Make that function over form! [/edit]
  16. Frank Hudon
    Frank Hudon Senior Member
    4,147
    about 7,000 km's with them on and 15,000 with them off and looking at the mileage spreadsheet guess what............ no difference. Now on the HCH '06 maybe those wheels make a difference but the mag on a Prius. spare me. I pulled the rings off one side of her car and called her out to have a look at both sides. Her comment was throw them away. They're in the basement. The Toyota Division rep that looked at her car said they are on it for airflow. I want to see the film from the wind tunnel to support the claim.
  17. Jack Kelly
    1,434
    Nope. You'd be going with function over form. :rolleyes:
  18. jayway
    jayway New Member
    SF CA
    Anyone who thinks the trim rings give you better mileage can buy my set and run two sets at the same time for really good mileage.
    Or better yet I have some magnets that you cap put on your carbuator and get 100 MPG
  19. darelldd
    6,059
    389
    Northern CA
    Doh! Beaten to the punch. My trim rings are shown to improve mileage by 10%* (one test vehicle, for one mile, no season testing complete). I am willing to sell them for just $59.99 plus shipping.
    *no guarantees of anything I say, beyond the fact that I'll sell mine to you.
  20. Walker1
    Walker1 Empire
    911
    FL
    I'm with you. Except; I have always loved mag wheels on any car. I never cared for plastic around wheels, etc.
    I had 2 Buick Grand Nationals. They all came with steel rims-(30 lbs. each). Then in the center they put this piece of crap plastic press on type of a center cap. It was unreliable and the xtra 80 lbs. was foolish. I purchased Crager Drag Stars, which only weighed 11 lbs. each. I can't remember how many of those stupid center caps fell off & never were seen again. THe Crager center caps screwed into the center of the mag.
    I really think Sir Gumdrop looks very manly without the trim rings. Also, when I took them off to view the rims they were already taking serious early stages of corrosion from living on a dirt road in FL.
    If I lost 2 MPG I still would leave them off. Milege isn't everything, even to a Prius owner.
