Trip 1 trip 2
Discussion in 'Prius c Main Forum' started by carolD, Aug 23, 2015.
  1. carolD
    carolD Junior Member
    82
    florida
    2015 Prius c
    Hi. I am fairly new. I got gas today for the first time in my Prius C 2. When I was don I reset trip meter 1 than I reset trip meter 2. What did I do wrong. Did I mess the computer up by doing that? Should I not have set back trip 2. Please someone help me with this. I have less than 600 miles on the car.
    49,507
    you can't mess anything up. i use trip one for each trip, and trip 2 for each tank.
  3. carolD
    82
    florida
    2015 Prius c
    But should I not have reset trip 2. I'm a little confused.
    49,507
    sorry, see my edit.^ i would have done the same, but if you want a lifetime, you shouldn't reset two.
  5. carolD
    82
    florida
    2015 Prius c
    Ok thank you. I thought I did something wrong. I will probably just use trip 1.
  6. bisco
    49,507
    i'm hoping for three trips on the next gen, trip, tank, lifetime.
  7. kendrew
    kendrew Junior Member
    Toronto, Canada
    For my C, the trip parts only go up to 9999km. I can't do lifetime.
    TC400 likes this.
  8. Mendel Leisk
    38,735
    The main things I use the trip meter for are:
    1. A ready reference as to how far I've gone since the last fill up
    2. A how-am-I-doing on the mpg (albeit exaggerated, by Toyota)
    And one trip meter does me fine.
    For logging fuel consumption per tank, I use the current and previous odometer readings. This displays every time the car is shut down, regardless of what you have trip set to, for about a minute.
    It's the only reading that can't be accidentally reset. I do use the trip meter too, but just for feedback, and as a crosscheck against the odometer.
    Fahfoofnik likes this.
  9. fuzzy1
    10,174
    For lifetime mpg, I use a paper fuel log and a spreadsheet on a computer. The trip meters are susceptible to getting accidentally reset not only by the driver, but also by shop technicians when during maintenance service. The later has happened to me twice.
    ewaboy and Mendel Leisk like this.
  10. DKTVAV
    DKTVAV Active Member
    510
    101
    I've never reset any trip so both of mine are lifetime. To avoid the techs reset the lifetime trip I've always left my screen at ODO reading. Last time I checked my lifetime MPG was about 65MPG, just don't know how far off the computer is.
  11. Mendel Leisk
    38,735
    I think any time the 12 volt is connected that "lifetime" trip meter is gonna be gone. And Toyota pads the mpg by around 7.5% in my experience.
  12. Oldwolf
    Oldwolf Prius Enthusiast
    816
    107
    NC
    2016 Prius v wagon
    I use Trip1 for gas tank fills and Trip 2 for oil changes.
  13. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
    I do my mpg by tank. I then write down the miles each tank got and manually do the math to figure out lifetime mpg.
    The trips only go to 10k then reset.
