Trip & Display Buttons not working after a jump
Discussion in 'Gen 3 Prius Main Forum' started by cpatty3, Jun 28, 2017.
  1. cpatty3
    cpatty3 New Member
    Las Vegas
    I have a 2010 Prius. The other day my battery died bc a friend left the lights and radio on without the engine running. I got a jump and the car is running again. But now the trip and display buttons on my steering wheel will not work. They worked prior to the battery dying. The rest of the steering wheel buttons work (temperature, volume, changing radio station up/down). Does anyone have any advice to get them working again?
  2. Quattro
    Quattro Member
    60
    28
    Silicon Valley, CA
    It propably got reset by the jump. You can turn the steering switch On/Off. Use the "DISP" button to go to the SETTING screen & there's a STEERING SWITCH option.
  3. Mendel Leisk
    41,960
    Yeah if you just disconnect the battery and reconnect, all the displays will revert to defaults. I think a near-dead battery will do similar.
    Orignal battery? I would get it checked out. Dealership or most automotive retailers will be able to see it's current "life", with an electronic load tester. Actually: if it is original, I wouldn't even bother with testing, get it replaced.
  4. cpatty3
    cpatty3 New Member
    Las Vegas
    It's not the original battery. I think the battery itself is fine. The only reason it needed a jump was b/c the car was running w/o the engine on for over an hour and therefore the car battery died.
  5. alexk345
    alexk345 Junior Member
    46
    india
    I have same problem. After jump all buttons in steering wheel not working. Any fuse that related to this buttons?
  6. ChapmanF
    18,602
    That sounds like something that's easier to do when the DISP button works.
    Mr. F and Haustoria like this.
  7. alexk345
    46
    india
    I have all button works except display and trip buttons and it happened after jump, Does it have fuse connected to it?
  8. Mendel Leisk
    41,960
    Maybe coincidence?
  9. Prius DIY nut
    Prius DIY nut Member
    92
    43
    Ontario, Canada
    Not sure about OP's 2010 Prius, but on my 2012 Prius this STEERING SWITCH menu option only turns on/off touch tracing blue-orange "floating display" feature for the steering wheel buttons. I could not find any information if these particular buttons can be turned on or off completely.
    Do you have a scanner to check for any trouble codes?
  10. alexk345
    46
    india
    Anyone found a solution to this?
