Trip Display Overstates MPG
Discussion in 'Gen 3 Prius Main Forum' started by Maverick Hiker, Apr 5, 2012.
  1. Maverick Hiker
    Maverick Hiker New Member
    94
    Baltimore MD
    My last fillup was for 9.539G and I had 501 miles on that tank (I had reset the Trip B display after my prior fill-up). This calculates to 52.52 MPG. Yet the trip B display had said I was getting between 55.5 MPG.
    This has happened every time I've calculated my mileage, I'm not getting quite the MPG that the dashboard display says I am getting.
    It overstates my mileage by 3-4 MPG.
    I am happy with my Prius overall, but it puzzles me why the trip display mileage does not seem to be accurate.
  2. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Congratulations...you are the 100th person to start a thread on this subject. :D :p ;)
    2 people like this.
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    In other words, it is a well known issue. Who knows why they did this.
  4. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    yes.. yes.... the car tends to be very optimistic with those numbers.. it's probably some number that was calculated with ideal conditions...
    conditions that you would probably not typically achieve.
  5. oldasdust
    oldasdust Member
    356
    47
    illinois
    Probably a Toyota thing being overly optomistic on mpg. My Honda is dead on after dozens of manual calculations i now trust the dash.
  6. d2mini
    d2mini Active Member
    519
    106
    Houston
    Pretty much every car's OBD (that i've ever driven) overstates the MPGs.
    Never believe the car. Always self-calculate.
  7. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    Welcome to the club. This bias for inflated mileage is an annoying distortion, but tiny, compared to the assumption that electricity is free when computing mileage for plug-in hybrids. After all, the Chevy Volt only achieves 90+ miles per gallon of fuel if you don't count fuel consumed generating the electricity that charges the batteries. Toyota should fix the slightly biased mileage reading in the Prius and all manufacturers of plug-in hybrids and pure electric cars should include fuel consumed generating and transmitting electricity used to charge traction batteries. I'm not holding my breath waiting for either of these advertising gimmics to be remedied.
  8. tonyrenier
    tonyrenier I grew up, but it's still red!
    362
    44
    Green Bay, WI
    My ex-wife had a Dodge Caravan with the big 6 saying she was getting over 30 mpg in town. I calculated it at closer to 12. So, keep calculating, the car don't want to.
    At least it's closer than that '02 Dodge.
  9. ghosteh
    ghosteh Member
    146
    57
    Illinois
    Sticker MPG ratings should show the car's mileage at 15, 30, 60, 100, & 200 miles.
    They should also show a cost/mile for plug-in hybrids, based on the national average of the cost of that paticular fuel (gas, electricity, CNG, etc.)
    The way they show it now is very misleading.
    ... but oh yeah, my dash display is off an average of 2-3 mpg also. Oh well, I don't care. I can still see that I'm getting great mileage.
  10. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    There is a sticky post in the fuel mileage section covering this. For what it's worth, the error will be fairly consistent (mine is 5.8% or roughly 3.6 mpg from my typical tank). Thus, if my MFD is reading 64.0 mpg, I know I'm roughly at 60.4 mpg (60.3 - 60.5 mpg). I know I have a ~12 gallon tank, thus can drive nearly 700 miles before I'm on fumes.
    Knowing your typical offset will make calculating your tank mileage fairly easily. I would prefer the displayed MPG to be accurate, but it isn't.....
  11. jabecker
    jabecker driver of Prii since 2005
    448
    78
    Portland, Oregon
    Of course you can verify that the amount of gas that you added in this fill up is exactly the amount of gas that you used from the last tank. Because, you know, all gas pumps are always right on track and there's no variance caused by the pump itself, the ambient temperature/humidity, etc. And if the amount added differs from the amount used by as little as a pint or so, it will skew your calculation, but not necessarily the calculation the car makes.
    Just saying.
  12. ProximalSuns
    ProximalSuns Senior Member
    1,877
    PNW
    You'd think it would be easy enough to change (or fix depending on one's viewpoint) by some minor reprogramming of the Prius computer. Customer comes in says please change my MPG by X% up or down and they jack in and change it.
  13. fuzzy1
    10,602
    As already pointed out, this is the topic of very many threads. In fact, it is even the second sticky thread in the GenIII Fuel Economy Forum, with more replies than you can possibly read today:
    calculated vs. computer MPG - Please post your results
  14. Maverick Hiker
    94
    Baltimore MD
    OK I will check that out. It just seemed to me that the displayed dashboard MPG would be an easy calculation to make and I was surprised it was not accurate.
    I know I can't complain when I am getting 50+ MPG. Especially considering I paid over $4.00 per gallon for my last tank of gas I am grateful for the good mileage.
  15. hoddy4
    hoddy4 New Member
    118
    NC
    Why would I assume that the hand calculation is dead on or even more accurate than the computer. There are variables in the hand calculation that lead to inaccuracies.
  16. Maverick Hiker
    94
    Baltimore MD
    Well I thought that the first time I filled up and hand calculated the mileage. But every time I calculate the mileage when I fill up I get the same results, I've done it about 10 times and the dash computer display seems to always overstate the mileage by about 3 MPG.
  17. boopie
    boopie Are we there yet?
    47
    Starbucks
    I think it's accurate in the way 1+1=2. I believe the problem is a "full tank" which varies from pump to pump which can lead to inaccuracies. I don't claim to understand why partial tanks (even minor ones?) cause this. :)
  18. Mendel Leisk
    41,889
    Coming from a second generation Honda Civic Hybrid, I the same experience: Honda accurate, Toyota inaccurate (in favour of the house). The mpg error with our Prius is around 7% I think.
    One dead-obvious motivation: Toyota get's free hyperbole reporting of mileage, from reviewers who take the in-dash readings as gospel.
    At least forum frequenters are mostly wise to it, but it is a frustrating issue. It would be in everyone's best interest, Toyota included, to fix this.
    Apparently the new Prius C and Plug-In are more accurate.
  19. Codyroo
    1,826
    515
    Pleasanton, Ca
    A gal at work has a hybrid Camry and when I asked her what her mileage was, she said it was 35 mpg. I asked her if that was the displayed value or a hand calculated value and....well.....let's just say she's not interested in her mileage to the point of actually CALCULATING it. Suffice to say, you will end up with many more happy customers if your reporting is "optimistic".
    I'm not saying this was the reason it is done, but it certainly plays into it. I think I'm in the minority when I calculate out my MPG's compared to the "typical" driver.
    MaverickHiker, for the Prius C, they did tighten up the calculations, but early reports are showing a 3 - 4% optimistic report vs 5 - 6%.
    Hoddy 4 - I've tracked my mileage over 2 years via Fuelly and a spreadsheet. For 45,000 miles, I'm showing a hand calculated tank average of 59.4 mpg. The computer displayed average would be 62.8 (I had to do some math on the spreadsheet to be able to calculate what the lifetime average computer displayed MPG is). Hand calculated will have some indeterminate errors that will cancel out over many tanks. The displayed value definitely has a determinate error.
  20. fuzzy1
    10,602
    I also don't know why you would assume something that can be checked.
    A long term fuel log will average out the tank-to-tank inaccuracies.
    That leaves uncertainties in the odometer, and in fuel pump dispensing accuracy. The former is easily checked against various external references, and at last check mine was running 0.2% low. The later is regulated by state weights and measures regulations in one direction, and in the other by retailer's efforts not to cheat themselves by giving customers free product. Together, these bounds are clearly tighter than the Prius GenIII computer error.
