Trouble Averted
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by RocMills, Oct 22, 2012.
  1. RocMills
    RocMills Active Member
    789
    276
    Las Vegas, Nevada
    Someone was looking out for me yesterday. Since reading posts here about how the right tire pressure can help increase MPG, and how most cars are delivered with a low tire pressure, I've been meaning to get mine properly set for some time now. I read the information on the tires themselves, and it said "Max PSI 55" ... and I had decided I wanted to try 40/38 to start with.
    My plan was to have the guys at Discount Tire do it for me (because it is very hard to find a working air machine in this town), or do it myself if I could actually find a working machine.
    Went out yesterday and Discount Tire was closed, so I headed for the a gas station up the road to see if they had a machine. They didn't, but they shared a parking lot with a Big O Tires which was open so I pulled in there and told the guy what I wanted.
    Thankfully, instead of just doing what I said I wanted done, he checked the label on the inside frame of the driver door. According to that sticker, the tires are only rated for 35! He looked up at me and said "You don't want your tires to hand grenade on you, do you?" Nope. So I asked him to simply set the tires to the recommended PSI and thanked him profusely.
    If Big O had not been open that day and I had used an air vending machine, or if that employee had blindly done as I asked instead of finding out what was right... I shudder to think what might have happened.
    I plan to send an email to Big O thanking the guy (I asked for his business card) for saving me from myself.
    JMD likes this.
  2. RocMills
    789
    276
    Las Vegas, Nevada
    One thing I'm curious about, though, why would there be such a huge difference between the Max PSI on the tires and Max PSI on the Toyota sticker?
  3. DKTVAV
    DKTVAV Active Member
    510
    101
    I've been driving my C4 with 45 front and 43 rear with no problem since the first week I bought my car in June. And I'm checking to have them at those psi every first week of the month. I'm driving 50/50 highway and city. I've read people put more than 50 psi here but couldn't find the post.
  4. Indy John
    Indy John Member
    75
    33
    Indianapolis
    The tires are NOT "rated" for 35 PSI. Toyota recommends 35 PSI. Their recommendation is a compromise for safety, comfort, economy, tire life, etc. Tires are NOT unsafe at the maximum cold inflation pressure. In fact, that is the minimum pressure at which the tire meets its load rating. At a few pounds more than the recommended pressure, you will be rewarded with better gas mileage, longer tire life, and crisper handling. In my book, you, any passengers, and the public will be safer.
  5. RocMills
    789
    276
    Las Vegas, Nevada
    I gather not all C models come with the same tires. What does the sticker on your door frame say for recommended PSI?
  6. RocMills
    789
    276
    Las Vegas, Nevada
    Indy, so my tires would not "hand grenade" on me if I filled them to 40/38? I kinda figured that the PSI rating printed on the tire itself was more reliable than some sticker, on the other hand I didn't feel like debating with the guy. I do have a tire pressure gauge, and now I know at least one place that has a working air machine, so I may bump up the pressure from the 35/33 if I'm sure it is safe to do so.
  7. DKTVAV
    510
    101
    They are Bridgestone like most of us in CA and the door recommended PSI is the same as yours if not all of vehicles in the US.
  8. RocMills
    789
    276
    Las Vegas, Nevada
    Harumph. I would have expected a tire professional to know that sort of thing. Now I'm disappointed and don't think I'll send that compliment letter after all.
    Thanks for setting me straight.
  9. DKTVAV
    510
    101
    One thing to remember: PSI reading in "cool" condition like sitting in the garage for few hours. Driving to the station to fill up will raise the PSI and that's why when I'm pumping them up about 1 psi more at 46/44 while I'm at Costco Tires.
    RocMills likes this.
  10. PriusCamper
    PriusCamper Senior Member
    11,105
    4,518
    Pacific Northwest, USA
    Only "trouble" averted is not getting good gas mileage.. You can go above 50psi with no issue if road conditions allow it.. The rougher the road the lower the psi and the smoother the ride. The more you experiment with different pressures the more aware of car traction you'll be, and thus the more conscious you'll be when avoiding an accident when traction matters most. It's also drastically changes mpg.
  11. fuzzy1
    10,170
    No, they won't 'hand grenade' on you anywhere near that pressure. The 35/33 label on your door frame doesn't know what tire model was originally installed on your car (a survey of our 2010's here found 3 different models for 15" wheels, and three more for 17"), nor what model you use as replacements when the originals wear out. So it doesn't know if the tire is labeled for 44 (like mine) or 51 or 55 psi.
    My 2010 arrived with the same door label you have, but at delivery the tires actually had 40/40/40/39 psi. More discussion here found that Toyota loads them up to 40 psi to avoid flat spots during their Pacific boat cruise. The dealer is then supposed to lower the pressure before delivery to the customer. Mine and many others were not, but we had no grenade reports. Some owners did have the correct pressure, while some had too-low pressure, likely a dealer trick to make a softer ride.
    I never lowered mine, in fact bumped them up slightly. The selling dealer never lowered the pressure during service (yes, they did check the pressures). But the one service at a different dealership while traveling caused a run-in with a so-called 'tire professional'. That shop was above 6000 feet elevation, and I arrived straight from a long highway run, so the tires were highway hot and nearly 50 psi. The tech insisted this was dangerous, and wouldn't let the car out with more than 40 psi. After the tires cooled overnight, and I returned to sea level, the tires were actually under-inflated (fronts were 33). The 'professional' didn't know about pressure rising as tires warm during operation, nor the approximately 1 psi per 2000 feet of elevation change that his customers experience as they head to Sacramento, less than two hours away.
    Have you ever seen warnings at high elevation, e.g. 10k-12k feet in Colorado, telling drivers to lower their tire pressure to prevent grenading? No, neither have I.
  12. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Why would Big O Tire want tp at 35psi? A soft tire runs hotter and wears faster and on the edges. That means owner will be in the tire shop sooner rather than later to buy new tires & maybe get an alignment. Go into an empty parking lot & practice some evasive maneuvers at 25mph or turn a corner at 25mph. If your tires squeal they are underinflated and may aggravate an unpleasant situation.
    Do you remember the Ford/Firestone fiasco? Ford strong armed Firestone into agreeing to 28psi on the door placard. What happened during an evasive maneuver? The hot tire failed causing a roll over.
  13. hieronymous
    hieronymous Member
    154
    92
    Auckland, New Zealand
    2013 Prius Plug-in
    If you google "over-inflating tyres" you may find some interesting reading, like the following link.
    Dangers of Over Inflating Tires | Hybrid Cars
    The sticker pressure is both a recommendation and a minimum, as you don't want your tyres under-inflated. I suggest you try a small increase, say 2 psi to see what the effect is, perhaps then a little more. I have always run my tyres 2 psi over; as tyres always lose air, +2 psi keeps pressures from going under the sticker pressure (with regular checks), and also tightens up the handling and cornering noticeably. I also inspect tread depth, and look for any uneven wear regularly.
    No-one knows how your car handles like you do; you be the judge!
    P.S. Invest in a good pump and a gauge and do your own tyres - I have an excellent high pressure push-bike pump that stands vertical with a tee-handle you push down; it does car tyres easily (make sure it has a valve for car tyres).
  14. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    RocMills,
    If you drive on decent roads, inflate up to max PSI as written on the sidewall without a worrry. If you bounce from pothole to pothole then be more circumspect.
    I top off my tyre pressures with a bicyle pump.
  15. Rob.au
    Rob.au Active Member
    960
    441
    Sydney, Australia
    i-Tech
    Our tyres are different and have different recommended pressures but I find it interesting that the stickers here migrated a long time ago from the door pillar to the glove box. Funny that it would be located differently... wonder what on earth the motivation for that was.
  16. SageBrush
    11,627
    2,530
    Southwest Colorado
    I still have trouble grasping how you folks manage, wandering around upside down all the time.
    Tracy and WE0H like this.
  17. jsfabb
    jsfabb Active Member
    617
    156
    Medford, NY
    First of all, there is some sort of safety factor built into everything, including tires. So over inflating by a mere 20% isn't going to be an issue, especially if the max psi is higher. I'm sure even the max psi has some sort of safety factor built into it.
    When I went for my 15K service early in the morning before work, I brought along my pancake compressor, because I knew that Toyota would reset the pressure in the tires back down to about 36 psi. So, when I left Toyota, I just pulled into a nearby parking lot and inflated my tires back to 42F/40R, because I have a 70 mile round trip to work.
  18. Ryephile
    Ryephile The Technophile
    418
    151
    24
    Metro Detroit
    Lots of good comments here. The door jamb sticker indeed is a minimum cold PSI recommendation to handle the indicated gross vehicle weight [aka loaded with people & stuff]. There are sometimes several recommendations on those stickers for various loads [e.g. 2 vs. 4 people], and various OEM tire sizes. It's all a legal disclaimer to keep the OEM's from being sued.
    For what it's worth, driving on the street doesn't heat up tires all that much, so after a long road trip you can expect 1 or 2 PSI increase from the tire being warm. Of course a bad alignment will heat up a tire more, as will aggressive cornering.
    The maximum inflation pressure molded into the tire sidewall is of course the maximum the tire manufacturer is willing to rate the tire at.
    So Toyota's sticker says something like 38 front 36 rear cold to handle the weight of the car + load, and Bridgestone says 55 psi max. These are your logical bookends. Now we get into things like fuel economy, comfort, tire wear, and handling. All of those aspects will dictate varying tire pressures for maximum performance in each category. It's up to the owner to determine what pressure they find optimal, be it based on a hunch or a full-blown data set. Most of us aren't taking tire temp readings across the tread width after a drive to determine how to tweak our pressures [and alignment], but that's just an easy example of the next step needed after simply guessing or seeing what happens.
    Long story short, unless you're willing to do some investigation, stick to the Toyota sticker recommendations based on how you load the car, or perhaps bump them up a couple PSI just to give yourself some leakage room. Tires after all don't seal perfectly; this is why you should check them literally every fuel-up.
    Cheers,
    Ryan
    Dylan Murphy likes this.
  19. RocMills
    789
    276
    Las Vegas, Nevada
    I've decided that at the next opportunity, I want to go up to 40/38. Whether I do it myself or not depends on the availability of coin-op pumps. Thank you everyone, very much, for clearing this up for me.
  20. fuzzy1
    10,170
    I wish this article had some technical backup, in particular on these two items:
    His traction claim violates my understanding of classical friction. His hydroplaning claim flat out contradicts the NASA and aviation industry articles that has been discussed here in the past.
    Absent some technical backup, I can't believe him.
    Jollyman likes this.
