Trouble Codes, Help: U0293, U0155, U0142, U0100, B2321 & B1206, C1311
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Paulo219, Jul 23, 2020.
  1. Paulo219
    Paulo219 New Member
    Seattle
    Hello my Prius friends. Recently my 2015 went from 51mpg to 46mpg. I ran a OBD2, several codes have popped up: U0293, U0155, U0142, U0100, B2321 & B1206, C1311. I've checked all the wiring, fuses, all are intacted and no burn fuses. Was wondering if u or anyone you know had this same scenarios and figured out the fixed. O'Reilly guys tested the 12V battery, tested good. Also, I'm trying to locate 20A HEV fuse, but unsuccessful.
    51,938
    what scanner are you using? clear the codes and see what comes back.
    a lot of things can cause mpg deterioration
