Trouble decoding battery block voltages over CAN
Discussion in 'Gen 2 Prius Technical Discussion' started by FirstFlight, Sep 3, 2012.
  1. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    I've hit a wall with soliciting the battery block voltages and resistances. Not sure if I'm sending the correct command or I'm missing something but this is the issue.
    I can send 7e3 2 21 cf and I get the correct reply of 7eb 10 12 61 cf.....
    I *think* I need to send the command of 7e3 30 7..... and then I should get back 7eb 21...., 7eb 22...., 7eb 23.... and 7eb 24.... There are two problems I can't get my brain to understand.
    1. When I send 7e3 30 7, I get two replies of 7e3 04 30 81 00 06 55 55 55 and then I get 7eb 02 70 81 00 00 00 00 00. This is not what I was expecting.
    2. Regarding the response, do the block voltages, block resistances and other battery information fall under byte D0 (21) or is the information a sequential response from 7e3 2 21 d0/cf/ce? In other words, even if byte D0 is 21, can it be different information? (if that makes sense)
  2. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    I am not handling the acknowledgement myself but looking at the log I see that OBDLink is sending
    7E3 30 00 00 00 00 00 00 00
    not
    7E3 30 7 ....
    You may give that a try. Good luck!
  3. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    I think I tried that last night and had no luck. During the day I'm going to write the code for a sequential response, which I believe it is. On my way home from work today I'll try it out and let you know if it works.
  4. lopezjm2001
    lopezjm2001 Senior Member
    1,146
    407
    Sydney Australia
    Hi FirstFlight,
    I have already done this using mmBasic V4.0 with CAN commands. The frame to send is
    7E3 30 00 01 00 00 00 00 00 , this is what my miniVCI uses. However
    7E3 30 00 00 00 00 00 00 00 also works.
    Must send all eight bytes of data.
    Answer is received at 7EB.
    [email protected] likes this.
  5. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    Yup, the 30 did it, thanks.
  6. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    I have one issue that I need to resolve. Maybe someone else has had this issue too. All of the battery block voltages work correctly but on occasion (once every 3-4 seconds) the block voltages for 8, 9 and 10 will show -327 and then on the next update go back to normal. Anyone else ever seen this issue?
  7. 2009Prius
    2,705
    510
    63
    I haven't paid much attention to the block voltages but I just plotted up the log from a recent trip and didn't see the abnormal value.
  8. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    It's probably in my code somewhere........
