Trouble reading a oil dip stick
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Tynyyn, Mar 7, 2019.
  1. Tynyyn
    Tynyyn Member
    102
    27
    Bella Vista Arkansas
    I pulled into the gas station to fill up with premium gasoline and decided to check the engine oil level because I was parked on a flat surface. Went to the front of the car, opened the hood, and pulled out the yellow painted round dip stick.
    Here comes the problem. As I pull the dip stick out I notice the oil is a dark honey brown. On one side of the dip stick it shows full. All the way to the top nib punched onto the stick. I turned the dip stick over and saw that the level on this side of the dip stick was below the bottom nib. Now, this is flummoxing to me since it looks like the tube the dip stick rests in has a bend and goes horizontal as it snakes towards the back of the engine.
    What say you fellows? Which side of the dip stick should I trust?
  2. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Let the oil settle for a few minutes after pulling out the dip stick, then reinsert and read again.
    Best way to read the level, is to park on a level surface and check it after the car has sat unused for some time (or overnight).
    Skibob and Raytheeagle like this.
    49,702
    go with the lowest reading. the rest is just a streak
    SFO likes this.
  4. Zeppo Shanski
    Zeppo Shanski Active Member
    293
    151
    Chicagoland
    Crummy dipsticks.
  5. Tynyyn
    Tynyyn Member
    102
    27
    SFO, you were correct. I let the car set overnight and looked at the dip stick this morning. Was 1/2 quart low. Thanks for the sage advise.
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,809
    Clearwater, Florida
    Yes let it sit overnight as it takes a long time for all the oil to drain back.
    The Prius g2 motor takes 3.6 quarts of oil with a new oil filter.
    I check my cars oil every sat morning. Unless it’s a high mileage Prius if so odds are good it eats oil so I would Check it every few days till you get an exact handle on how much oil it eats. If it’s a little oil eating monster move up to a 40 weight oil like 5-40. Keep it at the full line always.
    As far as the different level of oil on the dipstick I always use the high level.
    As the true reading.
  7. Mendel Leisk
    38,881
    If it's similar to gen 3, when you pull the dipstick out the first time it tends to draw oil up the tube. If you immediately reinsert and pull out the dipstick, it's going to have that drawn-up oil clinging well up the dipstick, making it hard to read the true level.
    The work around is to pull the dipstick, then wait about 5 minutes before the reinsert and pullout for the check. If at a gas station filling up, just pull the dipstick first, and then start pumping the gas. This 5 minute or so wait will give the oil in the tube time to mostly drain down. Also, check both sides; one side is usually clearer, less smeared.
    Moses Bruh likes this.
  8. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    :coffee:
    Raytheeagle and bisco like this.
  9. bisco
    49,702
    I defer to Ed :oops:
    He is the Fox after all ;)
    edthefox5, Raytheeagle and SFO like this.
  10. edthefox5
    10,096
    4,809
    Clearwater, Florida
    Lol...its not that much difference on the stick maybe less than an 1/8 of an inch between the high and low. But it is weird.
    Ed the Fox was my beloved Fox Terrier who's no longer with us. It's amazing I've been on this site 12 years come July. Thats alot of 12 volt battery questions lol.....
  11. Zeppo Shanski
    293
    151
    Chicagoland
    It's a shitty dipstick. Deal with it.
  12. Tynyyn
    Tynyyn Member
    102
    27
    Ed, you state that these motors eat oil. I've noticed that and somewhere read that the cause might be coked up rings. Do you have any insider info as to what the cause of the oil burning might be?
