Trouble with gas cap flap or door
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by FishHawk, Jun 7, 2007.
  1. FishHawk
    FishHawk New Member
    176
    I have had issues trying to open my gas cap. It seems as if the plastic gas cap retainer if not in it's proper place prevents the gas flap or door to open fully. There is a small recess where the retainer cable should fit. It it's out to the recess it prevents the flap from fully opening. Has anyone else had this problem?
    FishHawk
  2. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    <div class='quotetop'>QUOTE(FishHawk @ Jun 7 2007, 02:41 PM) [snapback]457532[/snapback]</div>
    Haven't even noticed. Will try to remember to check Saturday when i buy gas.
  3. richard schumacher
    7,664
    1,045
    United States
    If you mean, "it doesn't pop open automatically perpendicular to the car's skin when I pull the lever", that's normal. If you mean, "I can't pull it open that far using my finger", that's not normal.
  4. daronspicher
    daronspicher Active Member
    1,208
    Yes, I have this problem, it's a design flaw.
    I go to buy gas, I hit the thing on the floor to open the side door for the gas cap and I look back there to see it's still flat against the car, no way to get in.
    After pulling that lever and trying with my drivers license to get it to come open, I eventually get it. I had this problem this morning when I was gassing up.
    Once I get it open, I bend the little springgy flappy thing near the hinge so that for the next 30 or 40 fillups I won't have this problem..... Then, about 30 or 40 fillups, I'll have this problem again.
    The guy in the tahoe across the island was having a good time watching me try to break into my filler cap, I'm just glad he was kind enough to not outright laugh at me.
    You'd have thought they'd design it so the pulling of the latch kicks the door out as a minimum. The springgy thing could assist, but shouldn't be the primary.
    On the upside, I got 585 miles on that tank. My last pip had been blinking about 5 miles when I filled up.
  5. pinball
    pinball New Member
    121
    Surrey UK
    Had the problem, once.
    WD40 did the trick
  6. kmossbro
    kmossbro New Member
    This happened to me once also. I just figured that I did not do something right as it has not occurred again.
    Kmossbro
  7. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    Lubrication is required every few years. Releases eventually dry out from being exposed to the elements.
    I second the WD-40 suggestion.
  8. FishHawk
    FishHawk New Member
    176
    <div class='quotetop'>QUOTE(john1701a @ Jun 9 2007, 04:21 PM) [snapback]458802[/snapback]</div>
    I put the plastic spring thing behind the little spring on the gas filler and it seems to have cured the problem. I'll try the WD40 also. FishHawk
  9. subarutoo
    subarutoo New Member
    1,213
    23
    Chatsworth, CA
    Tell the Tahoe guy its been so long since you bought gas, that you forgot how to open the lid. :) :) :)
    My neighbor told me it takes $85 to fill up his Tahoe. I just smiled, and said "That's too bad."
  10. whodat
    whodat Member
    117
    Aptos, CA
    My 06 Prius gas cap door was not opening. I bent the metal tab on the inside of the door and now it works fine. Thanks PriusChat!
    Dave
  11. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    My 06 seems to do this sometimes. But it opens about 5mm to 1cm. Enough for me to stick my nail in and push out. But other times it works just fine... It's just Toyota's way of saying we dont need to fill-er-up. :)
  12. Patrick Wong
    18,200
    6,500
    My 2004 (103K miles) recently is having a problem with the gas cap door, where the leading lower edge of the door will rub against the body as the door is opened. Some of the paint chipped off the lower corner of the door because of this, before I realized the problem existed.
    I tried tugging on the door to see if I could realign it "manually", without success.
    Now while opening the door, I exert some force, pulling the door away from the hinge, to minimize the door's rubbing against the body. I should remove the hatch trim on that side to see if I can access the door hinge mounting screws and realign the door within the body recess.
  13. bgr
    bgr Junior Member
    Patrick, just curious if you ever got around to doing this and how difficult a job it is. I have the exact same problem you describe, though in my case it appears that the hinge pin has become bent. I can't see any way of straightening it without removing the fuel door itself. Thanks in advance.
    Merkey likes this.
  14. Patrick Wong
    18,200
    6,500
    I did not. Still living with the fuel door as-is.
