Trunk cargo net add
Discussion in 'Prime Accessories and Modifications' started by Sezy, Feb 20, 2020.
  1. Sezy
    Sezy Active Member
    431
    229
    37
    Saint Charles, Missouri
    2020 Prius Prime
    Added a 3 section cargo net from amazon to my trunk. Came with mounting screws,attachment points and a nut for them to grab onto. Removed the side trunk screws, pryed the trim back a little and eyed out where would be safe to screw the net holders in at. No interference with the tonneau. Took an extra step and filed down the screw tips incase they rubbed on anything. Made a pilot hold,slowly put the screw through but not all the way so I can add the washer holder. Tightened and put all side screws back in. Took like 20 minutes. 20200219_171645.jpeg 20200219_173430.jpeg 20200219_171640.jpeg 20200219_171713.jpeg 20200219_173439.jpeg 20200219_173447.jpeg 20200219_173448.jpeg 20200219_173455.jpeg 20200219_173836.jpeg
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    Not bad! Would you mind feeding us the link to the net on Amazon? Thanks!
    Sezy likes this.
  3. Sezy
    Sezy Active Member
    431
    229
    37
    2020 Prius Prime
    Amazon Link
    Zento Deals Heavy Duty Stretchable Black Mesh Net Cargo Trunk Storage Organizer- Keeping Things Secured and More Organize with 4 Plastic Hooks"
    [​IMG][​IMG]
    jerrymildred likes this.
  4. Tideland Prius
    16,445
  5. jerrymildred
    11,517
    14,137
    Tampa, FL
    Thanks, @Sezy! I just ordered one for my wife and one for me. (y)(y)(y)
    Sezy, dig4dirt and Prodigyplace like this.
  6. Mark57
    2,945
    2,738
    OK
    Ummm, are you going to tie each other up? Oh you meant for your cars . . . . :eek: Nothing to see here. :D
    Sezy, dig4dirt and jerrymildred like this.
  7. jerrymildred
    11,517
    14,137
    Tampa, FL
    Hmmmm. I hadn't thought of that. Everyone, close your eyes. :ROFLMAO:
    Mark57 likes this.
  8. Dennis_MA
    Dennis_MA Active Member
    185
    109
    Amherst, MA
    I used the Toyota one from my 2012 Prius. Works fine on my Prime. Eventually I will install some D rings on the floor for the bottom. It is working fine not connected for now.
  9. jerrymildred
    11,517
    14,137
    Tampa, FL
    At least on the 2017 they thoughtfully put threaded holes toward the front of the cargo area near where they were on Gen 3. But none toward the rear. :mad: I hope they have corrected that in newer model years.
  10. Mendel Leisk
    40,574
    Something wrong with the dimensioned pic in post #3??
    Units should be decimeters or something?
  11. jerrymildred
    11,517
    14,137
    Tampa, FL
    I wondered, too, but didn't comment. I saw that on the Amazon page, too.
  12. jerrymildred
    11,517
    14,137
    Tampa, FL
    Installed on both cars. If you put it on a Prime or (I assume) a Gen 4, check before putting screws through the trim. Quite a bit of electrical stuff back there. It's a perfect fit on the Gen 2. Prime is not ideal with the low height available, but it looks like it'll work. Of course, if you have a spare tire strapped down back there like I do only half the net is useable.
    Sezy likes this.
