Trying to drive Prius up my yellow metal car ramps, but I hit the bottom of front spoiler
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Apr 27, 2018.
  1. ski.dive
    ski.dive Active Member
    959
    241
    Hutchinson Island,FL. Mt. Snow,VT
    Trying to drive Prius up my yellow metal car ramps, but I hit the bottom of front spoiler?
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    Raytheeagle and Mendel Leisk like this.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    I had looked at those and wondered if they were shallow enough.
  4. TMR-JWAP
    6,404
    6,080
    Columbia, SC
    When I get home this evening, I'll measure the rise/run and post it. That way, anyone can do some quick measurements to see if they'll work for their model car.
  5. Mendel Leisk
    40,586
    Yeah, either some 2x8's on the approach, or get a floor jack.
    Raytheeagle likes this.
  6. DMC-5180
    DMC-5180 Active Member
    294
    134
    I’ve never liked ramps from the standpoint of them sliding out from under the wheel as you try to go up.
    These were the old school stamped metal ones a smooth garage floor. The slope is just too steep. Rear wheel drive is also part of that issue because no torque is being applied to the front wheels, so the wheel rolls backwards as the ramp shoots forward. If the ramp transition was a foot longer it would make big improvement.
    I’m surprised longer transition ramps aren’t more common given the low clearance and long front over hang of many cars in the last 20 years.
    iPhone X ?
  7. Mendel Leisk
    40,586
    Ramps make me nervous, haven't used them in over 30 years. Floor jack is more controlled, versatile. Especially inside a garage, floor jacks are too "exciting". With floor jack, you don't need to start the car, just so much more versatile. I have a cheapy 3 ton jack ($69 on Boxing Day sale), 3 ton and 6 ton jack stands (4 of each), heavy rubber wheel chocks (4).
    Also, my ace in the hole is squat section of tree trunk, about 13" diameter by 13" long: I push that in under a main cross beam, just aft of the engine bay, before crawling under to do oil changes.
    George W likes this.
  8. scona
    scona Active Member
    225
    206
    Courtenay, BC, Canada
    2013 Prius v wagon
    You need shallow ramps that give a lower lift, but adequate height so you can slide under the vehicle from the front and reach the oil plug and the filter.
    If you warm up the oil by driving a bit it helps the flow while draining and helps top up the HV battery. Put the Prius in EV mode and crawl slowly up the ramp with total control and the greatest of ease. At the top of the ramp put the car in Park and set the emergency brake.
    Shut it down, complete the work and exit in EV mode again. I add 3 litres of oil before coming down the ramp, just in case the engine should start itself, never know with these cars. Then start up the ICE to check for filter leaks, shut it down and top up the oil as required.
    A nice boring servicing, not a Daryl F Zanuck production but I am too old for those any longer.
  9. Mendel Leisk
    40,586
    We probably arrive at the same thing, but I let it drain well, button everything up, pour in the measured amount, as spec'd, call it done. I don't even check the dipstick till a day or two later, since it's so clear, and tends to be a little weird till it's settled down. This puts it just at the underside of the top mark, when I do check.
    #9 Mendel Leisk, Apr 27, 2018
  10. dolj
    dolj Senior Member
    8,217
    4,187
    Wellington, New Zealand
    Except for Gen 2 it is a measured 3.7 litres (3.9 qts (US)), with a new filter.
  11. TMR-JWAP
    6,404
    6,080
    Columbia, SC
    Photos and measurements included:
    The portion of the ramp that the car is driven up is ~20.25" long and 6.25" high (hypotenuse is ~22") the flat portion the tire will sit on is ~14 inches long. I placed the Rhinoramp and a yellow steel ramp next to each other where the top of the ramps are aligned with each other. The Rhino has about 2.5" more ramp length and is about 2.75" less in overall height, but only about 1.25" less for actual tire height since they don't have that lip along the edge. It's that strengthening lip that causes the interference.
  12. Mendel Leisk
    40,586
    The side ridges on the old steel ramps interfere more, too.
    scona likes this.
  13. a_gray_prius
    2,927
    783
    IL
    I drove my Gen2 Touring up on my buddy's 8000lb-rated Rhino ramps with no scraping. Just a datapoint.
  14. George W
    George W Senior Member
    911
    514
    San Antonio
    I saw those Rhino ramps at O'Reilly's Auto Parts store yesterday.
