TSB for lowbeams replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by texasboy77904, Feb 17, 2015.
  1. texasboy77904
    texasboy77904 Junior Member
    92
    Both my lowbeam bulbs went out at the same time on my 2011 back around 48k miles. I believe I read there is a TSB on this issue along with a strange engine rattle at startup.
    I asked the service rep to look into both issues. He's repsonse...." I think thats only up to 36000 miles not under 60000 mile powertrain warranty. If you want us to check it out it would be a charge."
    Im at 57k miles. At what mileage do the free TSB services stop?
    Thanks for any clarication.
  2. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
  3. texasboy77904
    92
    Yes i did. That is for recalls though not tsb.
  4. frodoz737
    4,297
    2,348
    33
  5. bisco
    49,460
    unless they do extended warranty, i think the tsb is just an fyi. for the startup knock, i thought they extended it. but if not, your best bet is to let the engine shut off before powering down.
  6. texasboy77904
    92
