TSLA in my hands
Discussion in 'Tesla' started by bwilson4web, Mar 5, 2019.
  1. bwilson4web
    15,513
    First file:
    A friend with a long range, Model 3 visited one of my two, L2 chargers, for a quick test:
    • 40A - definitely expected, the maximum rate for that EVSE
    • test at 1 minute - the Tesla Model 3 did a brief current drop which is how to test if the EVSE and circuit breakers are at a marginal rate. Resuming at 40A means this is a full power circuit and the Model 3 can easily handle a full 40A.
    Very clever, Elon's team.
    Bluegrassman likes this.
  2. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    I saw the title and thought "Man! That was a quick delivery!" :LOL:
  3. ETC(SS)
    6,544
    I was thinking that this was a placeholder and a confirmation that Bob will be sticking around for a while.
    One thing about Bob.
    We'll know exactly how much he paid, how fast it charges, range, repairs, etc.....
    Looking forward to it.
    Tideland Prius, jerrymildred and hill like this.
    49,397
    finally, the truth will out.
    #4 bisco, Mar 5, 2019
  5. farmecologist
    farmecologist Senior Member
    1,946
    1,785
    Southern MN
    Wow that was quick! Looking forward to your findings Bob! (y)
  6. Prodigyplace
    11,696
    11,318
    Central Virginia
    It was in his hands until his friend took it back :D
  7. el Crucero
    el Crucero Senior Member
    1,628
    699
    Inland Empire
    But did you drive it?
  8. DavidA
    2,328
    1,812
    Chicago western burbs
    Bob, is your EVSE's breaker at 50A, and you're charging at 40A? Did you set the charge rate limit on the car's screen, or did it automagically set itself at 40A charging rate?
    Still using the eMotorWerks 40?
    And I also misread your thread title as meaning you now have your 3 already. ;)
  9. bwilson4web
    15,513
    It is a 50A circuit and the EVSE is rate limited to 40A.
    Right now I have the reservation and costs. So I’m working on getting everything ready. The Prius Prime will be cleaned out and taken for detailing to clean out the dog hair.
    benagi likes this.
  10. DavidA
    2,328
    1,812
    :LOL: Those dogs. Hope it likes the new ride.
    I've got the same EVSE as you, but it is on a 40A circuit, with our house total at 100A. Great for the Prime, but I doubt highly we could install a 50A breaker for it, legally. But I think one can limit the car (3) to whatever one wants to limit charging to, at the upper end, i.e., 32A or something close. Would just take longer.
  11. Prodigyplace
    11,696
    11,318
    Central Virginia
    They should be comfortable with the new Dog Mode on the model 3.
  12. Trollbait
    11,514
    If you have a 40 amp EVSE that is not locked down to a lower draw, it should not be on a 40 amp circuit.
    An electrical circuit rating is for the peak amperage it can draw. The max continuous draw for anything plugged into it should be 20% lower. That is why vacuums with 15 amp circuit plugs aren't available at higher than 12 amps.
    The Prime's charger has a max draw of 16 amps, which is why you haven't had issues. Plug in a car that can draw the full 40 amps from the EVSE, and the base case is the circuit breaker regularly tripping.
    jerrymildred likes this.
  13. el Crucero
    1,628
    699
    Inland Empire
    I am getting out over my skis here. But my understanding is that you can only reach that 40a rate with the Tesla proprietary HPWC (High Power Wall Connector) which results in a 37 mph charge rate. A NEMA 14-50 (which is what I have) is less expensive and limited to 32a and a 30 mph charge rate. I'm sure I will be corrected if I am wrong. ;)
  14. DavidA
    2,328
    1,812
    Yes, no problem with Prime. 240v @ 16 amps is the most it can take anyway. Doesn't stress the EVSE or circuit in any way.
    Re: Model 3... I've learned that the current Model 3 has a charging limit of 32A (@240v) on the lowest of the three range battery packs. A 40 Amp 240v circuit should do just fine and is all that is required. The LR (325 miles) version's charger is 40A, which means a 50A breaker and wiring is suggested, at minimum. However, the charging can easily be software limited in the car to less than that - 32A for example, which essentially can ramp it down to the lower three battery pack top charging limits. Easily set on the screen.
    benagi likes this.
  15. bwilson4web
    15,513
    A more recent tweet suggests the real time intervals are "2-4 months", not "2-4 weeks." <GRINS>
    Source: Tesla produces first batch of standard Model 3 vehicles - Electrek
    Less than a week after having launched the new base versions of the Model 3, Tesla has already produced the first batch of Model 3 vehicles with the standard battery.
    The long-awaited standard version of the Model 3 is not only available to order, but it’s now also rolling off the assembly line.
    Electrek was able to confirm with a source familiar with Tesla’s production that the automaker produced an initial batch of over 500 standard Model 3 vehicles over the last two days.
    Today, Tesla has 550 standard Model 3 vehicles ready to ship.
    Elon just said that Tesla shouldn’t reach volume Model 3 standard battery pack production until ‘mid-year’.
    Source: Tesla shouldn&#039;t reach volume Model 3 standard battery pack production until &#039;mid-year&#039;, says Musk - Electrek
    That makes more sense. I assume production of the new version is going to be fairly low in the coming months.
    After all, they have been presenting the base Model 3 has been dependent on Tesla slashing its retail costs and as we reported last weekend, Musk admitted that they are just starting a review of the operations that will last for a few weeks.
    Actual meaningful savings probably won’t happen for a few months – when Tesla is going to start producing the $35,000 Model 3 in volume.
    With the increasing numbers of options now available for Model 3, I am starting to be curious about the mix of sales – especially when it comes to the battery packs.
    Before launching the Model 3, Musk estimated the average sale price at around $42,000 once all options would be available.
  16. Salamander_King
    Salamander_King Senior Member
    10,970
    8,853
    New England
    TSLA??? Oh, I see, using market symbol. (TSLA.O) ;)
    Prodigyplace likes this.
  17. Trollbait
    11,514
    I'm pretty sure the 20% I mentioned between the circuit rating and max load is in the electrical code. In other words, your EVSE may not be legally wired up. It may be possible to set the max load an appliance can draw to lower than what the equipment can handle, but these won't be settings an user can easily change.
  18. Prodigyplace
    11,696
    11,318
    Central Virginia
    @jerrymildred our resident electrician needs to chime in here.
  19. bwilson4web
    15,513
    Week 01 :: ordinary e-mails and phone calls to resolve questions. Encouraged by: Tesla Model 3 Standard Production Already Exceeds 550
    Tesla Model 3 Standard (the base battery pack option) is not only available for order but reportedly, the first batch of more than 500 were already produced.
    According to Electrek’s sources, some 550 Model 3 Standard are ready to ship. It’s more than one would anticipate in the initial stage, which suggests that Tesla is already ready for volume production of the Standard version.
  20. Prodigyplace
    11,696
    11,318
    Central Virginia
    Did your wife get a look at the Model 3? What were her impressions?
