1. The site is migrating to a new server this week, so there will likely be some downtime during that process. You can follow along here for updates.
Turbines to tap into Gulf Stream
Discussion in 'Environmental Discussion' started by GrumpyCabbie, Aug 30, 2010.
  1. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,119
    45
    North Yorkshire, UK
  2. spiderman
    spiderman wretched
    7,543
    1,557
    Alaska
    Seems like a great idea to me. And what output and all out of sight. One wonders about the possible collateral damage to marine life though.
    They have been talking for years about harnessing the tidal action up here in Cook Inlet. They get 30+mph tides.
  3. Trollbait
    10,666
    You can't go crazy with it though. The energy to turn these turbines is removed from the Gulf Stream by slowing it. Reduce it's speed too much and the UK gets colder. The actual amount a turbine reduces the stream, and the total number of turbines that can be put into use, might, more than likely, be of no consequence, but it isn't something to be just waved off without consideration.
  4. GrumpyCabbie
    6,722
    2,119
    45
    North Yorkshire, UK
    I'm not technical (I'm a cabbie remember) so I might be asking a dumb question here, but the energy required to turn these turbines is removed from the Gulf Stream? Could this slow it or stop it or would it need a massive number of turbines to make any difference?
    Does the same not apply to wind turbines? Forgive my ignorance.
  5. hyo silver
    hyo silver Awaaaaay
    15,232
    1,562
    off into the sunset
    Yes, technically, energy would be 'removed' from the Gulf Stream, but it's like saying the Eiffel Tower gets shorter when you stand on it. You'd need a gazillion turbines to have any measurable effect, and climate change may well divert the stream before we build that many.
  6. qbee42
    qbee42 My other car is a boat
    18,058
    3,072
    Northern Michigan
    It would take a massive number to make a measurable difference, but let's be realistic. We're talking about cooling the UK. Who really cares.
    :D
    :p
    Tom
  7. GrumpyCabbie
    6,722
    2,119
    45
    North Yorkshire, UK
    It's easy to go off somebody lol ;)
  8. xs650
    xs650 Senior Member
    4,539
    1,432
    Northern California
    Look at the bright side Grumpy, if the Gulf Stream does stop because of global warming, they could run the turbine generators as motors to start the Gulf Stream up again.:cool:
  9. qbee42
    18,058
    3,072
    Northern Michigan
    Or attach them to the UK and drag it south for better weather.
    Tom
  10. richard schumacher
    7,663
    1,035
    United States
    Not a dumb question at all. The power of the Gulf Stream is at least millions of megaWatts; it would take millions of turbines to begin to slow it by a measurable amount. The Gulf Stream will be altered by effects of global warming (changes in surface water salinity, changes in deep water flow, etc.) long before power turbines could affect it.
  11. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,526
    Tampa Bay
    I
    While the numbers don't indicate an effect due to power extraction, that many turbines undoubtedly could have some undesirable ripple effect that would show up, especially if we don't think the effects through. Who knows what spawning ground might be unnecessarily damaged if not explored beforehand. That said, proper design should be possible to provide both needed power and minimal adverse impact.
Loading...
