turbotax
Discussion in 'Gen 2 Prius Main Forum' started by harryg, Mar 3, 2005.
  1. harryg
    harryg New Member
    71
    Camano Island, Wa.
    Has anyone been successful entering the credit on turbotax? I checked
    with IRS and they say it goes on line 35 of the 1040 form. Asked turbo
    tax tech support and they say use the user guide on line. I think I've wasted my money may have to go else where. BTW I used their web SW, where I logged on to their site.
    Harry
  2. jrfaris
    jrfaris Member
    352
    Windward Oahu
    It's in the standalone version. If you are doing the interview, right when you start the deductions section there is a check box for other deductions that includes hybrid vehicle costs. Checking this generates some other questions a little later for electric vehicles and then clean fuel vehicles which is where you check the boxes indicating that you purchased a vehicle manufactured to meet the clean fuel vehicle requirements. If you open the 1040 form, there is a section for other adjustments to income which is where the $2000 gets entered. I haven't checked the 1040A so don't know if it has something similar or not.
  3. rick57
    rick57 Member
    572
    Circleville, Ohio
    I have used Turbo tax for the last few years. I know when I go thru the interview,it ask the question about Electric or Hybrid vehicles. Don't know what line but it should put it on the right line when you answer the question. I use Deluxe at home but did my daughters online using the Standard version.
  4. harryg
    harryg New Member
    71
    Camano Island, Wa.
    I did enter as a "clean fuel vehicle", checked all the right boxes, when all was done the credit never turned up anywhere, and of course I have to pay, so I'mm looking for any deduction I can find. Thanks for the replies.
    Harry
  5. tag
    tag Senior Member
    2,526
    Chicago
    I checked the TT web product and the interview and other components are virtually indistinguishable from the standalone version I have. So the deduction is definitely in there and should have appeared on Line 35 if the appropriate boxes were checked.
    One thing of which I'm fairly certain is it won't work with a 1040A since there's no place to enter the deduction on that form.
  6. pafoss
    pafoss Plug-in Member
    Denver, CO
    In order for Turbo Tax for the Web to register your answer correctly and give you the $2000 federal deduction, you must check nearly every box on that screen. Including very odd ones like "Was you vehicle modified to use clean fuel?" There some that I didn't check and didn't get the credit. Frankly, the software/web site uses very poorly worded text on that page. So once I just checked about every box on that page, it applied my deduction correctly. Unfortunately, I had already filed my 1040 before I noticed they didn't give me the clean vehicle deduction. So I just corrected the error, and filed a 1040x. I should have a $500 refund coming to me now according to Turbo Tax for the Web.
    Good luck,
    Powers.
  7. brosnan
    brosnan Member
    159
    Silicon Valley
    Keep clicking more boxes on the clean fuel vehicle deduction page until it lists the hybrid vehicles (2004 Civic, 2004 Prius, ...) after you hit "next". If it never asked you which hybrid model you bought, then you didn't click enough boxes in the first level clean fuel checklist.
  8. PriusDreamer
    PriusDreamer Member
    138
    Long Island, NY
    You shouldn't have someone do your taxes for that reason. If you can't get the program to put 2000 on line 34, Merely override line 34 and force the issue.
  9. Dion
    Dion New Member
    128
    Jersey City, NJ
    I used TurboTax for the Web. You have to check every box on that page to get the deduction. The instructions are not clear. It shouldn't work that way. My problem was different. I used the standard version through the IRS site to file for free and when I got to the end it would not let me file unless I paid $29.95. What a racket. By the way the standard version does not allow you to import your data from the previous year which is why I used TurboTax in the first place. So I had to enter all my data and still pay the premiere price. I will call for reimbursement and never use TurboTax again. There are plenty of other free web tax services.
  10. harryg
    harryg New Member
    71
    Camano Island, Wa.
    Thanks for all of your suggestions, after I checked all but "none of the above"
    it worked and went to the right screen, and gave me crediit. Again thankyou all! I received more knowledgeable support here than from turbotax tech
    support. Plus, I enjoy reading all the posts, we soon will be upgrading our cells and will be researching BT compatible cells, and I bet I find all I need to know here as well!
    Harry
  11. chanterelle
    chanterelle Member
    115
    San Dimas, CA
    2020 Prius Prime
    Dion -- from my understanding, you actually have to link thru from the IRS web page in order to get the free e-file. You can't just go to Turbotax.com and complete the return and e-file for free, or use the TurboTax that you buy off the shelf, although this one does allow you to file for reimbursement for one return e-filed.
    This is true whether you use TurboTax, Taxcut, Taxfree, or any of the other approved e-file vendors.
    From the sound of these problems from Turbo Tax, I am glad that I use Taxcut!!
  12. Dion
    Dion New Member
    128
    Jersey City, NJ
    chanterelle,
    I did link to TurboTax from the IRS site. I followed all the instructions on the IRS site and the Taxfreedom.com site that the IRS site brings you to. It still charged me to file. The problem is that it thinks I used the Premiere version or at least charge me for the Premiere version. I click on and used the Standard version which is suppose to be free. I know I used the Standard version because it would not allow me to import my data from last year. I think they try to charge you inspite of which ever version you use. At least that was my experience. One of the techs said that sometimes there is a bug in the software billing and some people are billed when using the free version.
    Anyway, I just called and got the reimbursement after waiting on hold for two hours. That's why I will never use TurboTax again.
  13. chanterelle
    chanterelle Member
    115
    San Dimas, CA
    2020 Prius Prime
    Dion - Sorry bout that. I have heard lots of stories about people who thought it was free to e-file, but found out too late that they had to go thru the IRS website. Most of them didn't.
    Glad that you were able to get the reimbursement, though!
