Turn 2018 Prius display on
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by zetapam, Sep 15, 2020.
Tags:
  1. zetapam
    zetapam Junior Member
    Boynton Beach, Florida
    2018 Prius
    Hi. My display turned off yesterday (navigation, audio, phone...) Please tell me how to turn it back on. I have tried Google, YouTube and the 2018 Prius Manual. Thanks!
  2. booke02
    booke02 Active Member
    391
    415
    Israel
    I had a similar problem after a failure of my 12V battery. Turned car off/on and problem was resolved.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,803
    2017 Prius c
    Sounds like you have a display FAILURE.
    Hope you are still under warranty.
    Unless you turned the brightness setting all the way DOWN, it should never go completely OFF.
  4. zetapam
    2018 Prius
    I turned the car on today, and the display is still off.
  5. zetapam
    2018 Prius
    Hi. I am still under warranty. I did not touch any of the buttons prior to the display turning off. According to the manual, there is actually a button to turn the display off, but then I can not find anything to turn it on. I was literally driving down the street and it just turned off.
  6. krmcg
    2,592
    2,392
    Whittier, CA
    Try pushing the power (volume) button in for 10 seconds. That will reset the audio system.
  7. zetapam
    2018 Prius
    Sounded like a great idea, but it did not work. Any other suggestions?
    krmcg likes this.
  8. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
  9. sam spade 2
    7,035
    2,803
    2017 Prius c
    Well then pushing that same button a second time should turn it back ON.
    If that doesn't work, yours has FAILED.
    Take it in before your warranty expires.
  10. zetapam
    2018 Prius
    Today the car will not start at all. The screen stated "Low 12-V battery. I have ToyotaCare coming to my house now. Sounds like the battery needs to be replaced. Thank you for your advice (and everyone else that posted here.)
    bisco and krmcg like this.
  11. zetapam
    2018 Prius
    Hi. You were correct! The car would not turn on this morning because of the battery. I went to the dealership and the battery was fixed. The fuse was a totally other issue, which caused the display to turn off! Thank you so much for your help.
    FuelMiser and krmcg like this.
