Turn off car during charging battery, good or bad?
Discussion in 'Gen 4 Prius Main Forum' started by littlebird002, Nov 5, 2017.
  1. littlebird002
    littlebird002 Junior Member
    37
    CA
    Many times, the engine kick in to start charging the battery after I full stop and going to turn off the car.
    If I just turn off the car, the car will sudden shake then off.
    Will this good or bad for the engine? Or I should wait the charging cycle complete?
    Thank you.
  2. Fester
    Fester Active Member
    201
    198
    Ohio
    Personally, I just wait a bit for the charge to finish and the ICE to shut down.
  3. littlebird002
    37
    CA
    Sure. Maybe I should wait for it complete also.
    49,519
    try adding a few seconds at a time to shutting it down, and see if the shaking goes away at some point.
    you may not need to wait until it shuts down itself.
    RCO likes this.
  5. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    No, just drive it, turn it off like normal. Good chance that it's running the ICE to run the heater - which will be no use when you get out again. The battery charging (and heating) will just pick up when you start next.
    Roger T and RCO like this.
  6. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Some say it's better for the engine to wait. I just shut off the car. I think it's a waste of gas.
    RCO likes this.
  7. bisco
    49,519
    i think that's only if it is cold and during the initial warm up stages.
  8. IAPrius
    IAPrius Active Member
    120
    140
    West Des Moines, IA
    I don't know why people overthink so many of these things - when you arrive you slow down, stop, put it in park, and turn the car off. We really don't need to make it any more complicated.
    kithmo, Harters, alanclarkeau and 2 others like this.
  9. krmcg
    2,592
    2,390
    Whittier, CA
    Great take!
  10. bisco
    49,519
    well, 'sudden shake' can be disconcerting. it's not normal.
  11. RCO
    RCO Senior Member
    3,709
    5,184
    Cornwall
    What! Happens to me all the time and I thought it was somebody walking over my grave!
