Turn off indicator click noise
Discussion in 'Prius c Accessories and Modifications' started by Joss, Sep 25, 2013.
  1. Joss
    Joss Junior Member
    Melbourne, Australia
    I'm wondering if anyone knows of a way to silence my indicator.
    Each time the light turns on and off there is an artificial clicking noise and I really want to mute it.
    Can anyone suggest an easy way to adjust this unruly noise?
    Thanks, Joss.
  2. xliderider
    xliderider Senior Member
    8,056
    3,223
    Honolulu, HI
    Turn signal? It's supposed to make noise, so you don't forget to cancel it, and be the one driving with your signals flashing without a clue...
    Prius_Cub likes this.
  3. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    I don't think the clicking is artificial. It comes from the relay operating.
    SAMSUNG-SGH-I747 ? 2
    xliderider likes this.
    51,154
    bypass the relay and use the stalk manually to create flashing as you need it. not sure about legality tho...
  5. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    How about leave it alone and use hand signal instead, lol.
    los panda likes this.
  6. bisco
    51,154
    but my elbow clicks when i bend it.:cool:
    Jonny Zero likes this.
  7. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    So do turn signals. :) This will just remind you that you need to disengage when you are done with the turn. :ROFLMAO:
