Turn off Maintainence Required Light
Discussion in 'Gen 2 Prius Technical Discussion' started by sumit, Jun 25, 2006.
  1. sumit
    sumit New Member
    16
    I just did an oil change on the car but can't figure out how to turn off the Maintaince Required Light on the dashboard. Any suggestions?
  2. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(sumit @ Jun 25 2006, 02:49 PM) [snapback]276608[/snapback]</div>
    Yes, read the owners' manual or perform a search for "Maintenance Light" on PriusChat .
    P.S. It does help if you correctly spell "Maintenance" when performing the search.
    P.P.S. Here you go: maintenance light
  3. TonyPSchaefer
    14,816
    2,497
    66
    Far-North Chicagoland
    <div class='quotetop'>QUOTE(IsrAmeriPrius @ Jun 25 2006, 05:06 PM) [snapback]276609[/snapback]</div>
    If you can tolerate the ribbing, someone will eventually give you the answer. :D
    I change my own oil. I keep a notebook in the garage of things I've grown tired of looking up. Do yourself a favor and do what I did: copy the instructions onto something else and keep it next to where you keep your quarts of oil. Or perhaps in the glovebox or wherever is convenient for you.
  4. john1701a
    john1701a Prius Guru
    12,754
    5,245
    57
    The USER-GUIDE has answers to common owner questions... like this one.
  5. finman
    finman Senior Member
    1,287
    111
    Albany, OR
    2014 Nissan LEAF
    Hold down the ODO button, while powering the car on until the odometer display shows dashes, then zeroes, then back to total miles.
    Cheers,
    Curt.
