Turn off push start?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by taniadaykin, Apr 16, 2015.
  1. taniadaykin
    taniadaykin New Member
    australia
    2014 Prius c
    Hi :) Sorry if this has already been covered. I have just picked up my prius c (2014) and the smart key is causing me problems :( When I go to the beach I can't take the key in the water like I can with a normal key and I can't throw the key inside the car and lock it with the manual key because it knows the key is inside :( Page 449 of the manual says that turning off smart entry and start system is a customizable option but no instructions on how. Bloody gadgets! Thanks heaps, Tania :) xxx
  2. se-riously
    se-riously Active Member
    263
    114
    SF Bay Area
    2014 Prius Plug-in
    If you can do it, it would be via the touchscreen of the stereo. If it isn't an option, then it has to be dealer programmed.
    49,500
    put the fob in an altoids tin.
    someone said you can put the fob under the gas cap lid and it won't pick up the signal.
  4. taniadaykin
    australia
    2014 Prius c
    Thanks :) I will take it to the dealer :) xxx
    Way cool! I will try that :) xxx
    Didn't work :(
    Thanks but I think what I'm going to do is take it to the dealer and if they can't do it I'll pull the battery out of the keyfob and leave it in the car; I'll just have to touch it to the button for starting as if it had a flat battery :) Thanks heaps everyone :) xxx
  5. bisco
    49,500
    all the best.(y)
  6. 00-00
    00-00 Member
    115
    68
    s/e idaho
    2015 Prius c
    You could also just wrap the fob in aluminum foil. The car will not recognize the fob's electric signals. Leave the fob anywhere in the car. Take the key with you.
