Turn off safety beeps
Discussion in 'Gen 4 Prius Technical Discussion' started by athas17, May 5, 2021.
  1. athas17
    athas17 Junior Member
    Los Angeles
    2019 Prius
    Is there a way to turn off the constant beeping of the warning signal when I get close to an object? For example, I have to pull up close to the drive-up window at a fast food restaurant, and the car is upset and beeps the entire time I'm waiting for my food.
  2. Tideland Prius
    16,125
    That'll be the Intelligent Clearance Sonar.
    The quick solution is to put the car in Park (because the forward-facing sensors are active in Drive and at low speeds).
    If you want them permanently off, there's a setting in the menu, accessed via the 4.2" MID and steering wheel buttons. (Park Assist OFF).
    Doug McC and alanclarkeau like this.
  3. MIkeDr
    MIkeDr Active Member
    252
    137
    Seattle, WA
    2020 Prius
    XLE AWD-e
    There are various settings you can access with a Carista dongle and app. I have mine set so that the beeps don’t happen in neutral, for instance, and in general occur at a lower volume.
    PtPri likes this.
  4. dewski
    dewski Junior Member
    16
    UTAH
    2021 Prius
    XLE AWD-e
    Can you kindly direct me of what you did in the Carista app to turn them off while in neutral? It's super annoying in the car wash! lol
  5. MIkeDr
    252
    137
    Seattle, WA
    2020 Prius
    XLE AWD-e
    To be honest, I’m not sure of the exact setting any more. It seemed relatively intuitive when I did it though. If you post all the screenshots of the options available, I should be able to direct you.
  6. beef jiggles
    beef jiggles Member
    135
    34
    Colorado
    Just read through all the settings. There are a lot. You need the paid version. Take 30 minutes and set your car up the way you want.
  7. Mambo Dave
    Mambo Dave Active Member
    640
    306
    2019 Prius
    L Eco
    There was for me - I read the reviews, and noted the owners complaining about those beeps so much, so I bought the model without that feature. L Eco for the win.
  8. Harters
    Harters Active Member
    335
    424
    UK
    Excel
    Press the P button and the beeping stops. It doesn't take a moment to put it back into drive when you are ready to get going again.
