Turn Signal Activates Both Tail Lights?
Discussion in 'Gen 2 Prius Main Forum' started by jimolson, Aug 28, 2020.
  1. jimolson
    jimolson Member
    147
    58
    Indianapolis, USA
    Can anyone suggest a starting point to diagnose a 2006 Prius that flashes both tail lights rather than one whenever a turn signal is engaged?
    Is a broken emergency flasher pushbutton a good first guess?
    Thanks in advance for any recommendation.
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    I recommend first that you have a moderator delete this thread and stick to just one thread asking this question. Otherwise it's going to generate a ton of confusion with two separate conversations going on.
  3. PriusCamper
    PriusCamper Senior Member
    12,064
    4,896
    Pacific Northwest, USA
    Has the vehicle experienced any damage? Maybe the wiring harness got damage and wires got crossed? And yes, unplug hazard plug and see if that changes anything?
