Turn signal and Hazard light issue
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by seven9, Dec 30, 2016.
  1. seven9
    seven9 Junior Member
    US
    2013 Prius v wagon
    OK I just noticed I have a issue with my turn signal lights not working up front. So I look to see if they work in the back of the car. an when I turn either side they both flash. but if I use the left they both work but the left side is brighter. An that's with the headlights either on or off. But when I use my hazards only the back work an not the front. Any suggestions.
  2. Air_Boss
    Air_Boss Senior Member
    3,939
    1,076
    New Yawk
    Has the car had any electrical work done on it recently, or in the past due to crash damage? From the description, there are discontinuities (fronts) and cross/back-signaling (rears).
  3. rjparker
    rjparker Tu Humilde Sirviente
    7,917
    4,678
    Texas Hill Country
    The easiest answer might be a bad ground or wiring connection but it's hard to say. I would certainly check the fuse, sockets at the bulbs and grounds. Other than that, you could take it to a dealer. A good auto electrical shop may be able to help using the diagram attached. There is no "flasher" chip as the function is integrated into a bigger dash module. IF you have changed to LED lamps change back to normal.
  4. rdgrimes
    rdgrimes Senior Member
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    ;)- any rodent problems around home?
  5. seven9
    US
    2013 Prius v wagon
    The car is completely stock an no accidents I guess I'll take it to the dealer to get it checked out
  6. Air_Boss
    3,939
    1,076
    New Yawk
    Moisture/corrosion in the connectors?
  7. EZW1
    EZW1 Active Member
    722
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    Let us know what you learn.
  8. Abdullahi
    Abdullahi New Member
    Norway
    Can any when tell me my perius plus arven 2012 hazard light constantly blinking change switch and relay back radio. Where Can i find relay... og this car hasn't relay any help
  9. Gasketblower
    Gasketblower Junior Member
    44
    Did you get it repaired ? I have the same issue
