Turn signal flasher location???
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Toppcat, Mar 16, 2016.
  1. Toppcat
    Toppcat Member
    223
    69
    Northern California
    2015 prius package 5 w tech package and HUD display, I found a flasher mounted up between the fuse box/ module assembly mounted on a clip! I have a led replacement flasher, but clip mounts and pin locations don't line up? I watch the video but I have nothing in area! Or I just need to install the resistors? Or it could be a combination circuit assembly where multiple function module all in one ?
  2. cproaudio
    cproaudio Speedlock Overrider
    2,401
    759
    CA
    Gen 3 Prius has a flasher that can be replaced with an LED flasher
    . Prius C and Prius V have the flasher built in to the combination meter and need resistors.
