Turn signal flasher
Discussion in 'Gen 3 Prius Accessories and Modifications' started by katiesdad7, Aug 8, 2011.
  1. katiesdad7
    katiesdad7 Member
    172
    25
    Stuart, FL
    I changed to LED bulbs for the turn signals and now I get the real fast flashers. I have the new flasher for the LED's but where the heck is it and how do you get to it?
  2. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    In most cars, the flasher unit is in the fuse panel. The locations (I believe the Prius has 2) will be shown in the owners manual.
  3. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
  4. offroader
    offroader Junior Member
    44
    It's under the dash just next to the brake switch it's kind of hard to get to but if you can reach up there make sure to press the release clip on the side I had a heck of a time and had to get a screw driver up there to release it.
  5. SCRWGas5
    SCRWGas5 New Member
    156
    Charlotte, North Carolina
    I'm not finding the topic whin the LED lights thread. Is it in there somewhere?
  6. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
  7. scottmcphee
    scottmcphee Junior Member
    22
    If you're putting in LED signals, you'll need to use load resistors (yuck) or switch to an LED compatible flasher that won't need load resistors. You can find a raft of CF-xx flashers made in China on ebay or whatever that are somewhat compatible with LED signals but have issues with "first blink" being slow or malformed.. and alarm dis/arm flashes not quite working. But what do you expect for cheap?
    Since you're going through the trouble to upgrade signals, may as well consider an upgraded function flasher like the one that adds convenience signaling (one-touch) and funky new hazard modes (like wig-wag anyone?).. Google "tapturn flasher" it works on the range of Prii.
  8. Mrpcar
    Mrpcar Active Member
    542
    253
    Chino Hills, CA
    Related but not the same question. Is there such mod or hack that allows the signal to blink 3 times when just you momentary touch the signal stalk like the ones on the European cars?
  9. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    The post above you mentions the tap turn flasher, which you can use to swap out the stock flasher.
  10. J Dunn
    J Dunn Active Member
    118
    169
    Newport Beach
    I got the flasher too....read the thread on how to change the relay flasher...got on my back which cracked as I slid under the dash...looked up under the dash and said eff this! I can live with the rapid flash!
  11. A.Reyes
    A.Reyes Active Member
    270
    178
    Beaufort, 29902
    Turn your flashers on and listen for the click. That's what I did on my subaru. Doing LED conversion on my car prius soon.
    Or buy load resistors...just tap into the rear turn signals and done!
  12. scottmcphee
    22
    In the theme of power saving, load resistors suck, right?
    Switching to LED signal bulbs are great for lowering power demand.
    Lightening the overall electrical load placed on the alternator will use less gas.
    Here's a question, if the duty cycle of signal flasher was changed from 50/50 (percent on to percent off) to something having less on time in proportion to off time... it would draw less average power. Over the life of the car, and if you're a diligent signaller ... it might even save a little gas. I was wondering if there'd be any interest from the extreme economizers in having a "Prius version" flasher that has say, 40% on to 60% off duty cycle per blink? (While maintaining the regulation flash frequency of around 90 cycles per minute).
  13. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    You can move to California where people have stopped using their turn signals because they're tired of inconsiderate drivers closing in on them as soon as they see their turn signals :cautious:
  14. scottmcphee
    22
    I don't get the connection to my post.
    But I hear you.
  15. Eugene Hong
    Eugene Hong Member
    114
    30
    Bay Area, CA
    Lol.
  16. nivlac915
    nivlac915 Member
    77
    56
    up in the hills of covina, west side
    when changing the turn signal bulbs (7440) from amber to clear or red, you will get hyper blinking. to eliminate that you will have to purchase resistors for each bulb changed. i had to do that to stop the hyper blinking.
  17. doc2mee
    doc2mee Junior Member
    Using load resistors will not help in reducing current usage as electric current will be shunted through the resistor thus negating any current saving. Only good thing is LED is longer lasting and looks nicer. I think the flasher runs on current load, i gets heated up and the bimetallic strip disconnect and the bulbs flashes, and when the current is low the strip gets less heat so flashes faster.
  18. scottmcphee
    22
    The really antique flashers used to work this way.
    Almost all modern flashers do current sensing internally with electronics and do not rely on heated bimetalic strips.
  19. doc2mee
    Not very sure about modern electronic flasher but if the flasher is in the relay then I think it can be modified to a lower duty cycle. I always believe a bimetallic strip was the most reliable and wasn't upgraded.. hehe must have been wrong.
  20. gandG
    gandG New Member
    28
    Nowadays (2015) for about $6 you can get an LED-compatible replacement flasher - plug in replacement (BUT very hard to get at it)
