Turn signal lamp came loose
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by spilledwater, Mar 13, 2025.
  1. spilledwater
    spilledwater New Member
    South Carolina
    My left side turn signal lamp came loose and is dangling inwards. It appears that one of the clips is broken however dealership said I would have to order the whole thing. Would there be any better way to fix this?
  2. MAX2
    MAX2 Senior Member
    1,436
    482
    101
    Third planet from the Sun
    Super glue.
  3. ASRDogman
    ASRDogman Senior Member
    7,111
    3,713
    There are several video's of placed showing how to rebuild them with melting cable ties.
    Or other types of plastic.
  4. Frontporch
    Frontporch Active Member
    494
    107
    Nj
    I would try to identify what is broken. If its just the clip on the top #2, then it might be reasonable to replace it. The light (1) fits into the housing (4) and the clips attach top and bottom to the housing. That whole assembly connects to the bumper with the clips #2 and #3. My guess is #2 is broken.
    I just reread the original post. Hmmmm... is the dealer lying? looks like part # is 81519 RH and 81529B LH. Looks like they are availalbe. Check the numbers, I did a quick search.
