Turn Signal Won't Turn Off
Discussion in 'Gen 2 Prius Technical Discussion' started by DPZ, Aug 20, 2017.
  1. DPZ
    DPZ Junior Member
    Arizona
    2007 Prius. The Right Turn Signal Indicator will not turn stop flashing.
    The only way to stop it is to remove the bulbs or the fuse. I disconnected the wires at the multifunction switch and the left turn signal and head lights will not work but the right indicator keeps flashing. The only thing I can think of now is the Flasher relay under the dash is defective. Does anyone think a bad relay could keep just the right indicator constantly flashing but not the left one?
    Any Ideas?
    Thank you
  2. Beachbummm
    Beachbummm Senior Member
    1,160
    392
