Turned 100,000 miles on my 2010 Prius 6/17/15
Discussion in 'Gen 3 Prius Main Forum' started by PanamaJim, Jun 17, 2015.
  1. PanamaJim
    PanamaJim New Member
    solrunner, Snow, Nora and 1 other person like this.
    49,470
    (y) great video, new toyota ad?
  3. Crosby
    Crosby New Member
    Phoenix, AZ
    Congrats! Pretty car...looks identical to mine. :) I have 105,000 on mine.
  4. law
    law Member
    188
    33
    CA
    Congratz!
  5. Spooled
    Spooled Member
    142
    25
    Concord, CA
    anyone know the highest 3rd gen milage?
    I met a cabbie w a 2010 that had 180,xxx on it
  6. JoeM(GA)
    JoeM(GA) Member
    40
    35
    Atlanta,GA
    108,000 and some change on mine, best money I've ever spent!
  7. milkman44
    milkman44 Active Member
    591
    386
    Ky
    Just changed the trans fluid for the second time and rotated the tires at 134K miles. I checked the brake pads and they're not even half worn yet. So far this has been a good run, have saved $7000 in gas vs my other car. If I buy another car, IT WILL BE ANOTHER PRIUS!!!!! My only complaint, road noise.
  8. Spooled
    Spooled Member
    142
    25
    Concord, CA
    +1 on road noise...what kind of tires do you have?
  9. milkman44
    591
    386
    Ky
    I have the Michelin Defenders with 60K miles so they will be replaced before winter. The part that really annoys me is the joints in the road sounds like thump jars through the whole car body. I'm thinking new shocks and struts may be a solution, 134K miles on the car. I will lower the air pressure and see if that helps, running at 40psi now but tried 35 and not much difference. I'll drop to 32 and see what happens.
  10. Spooled
    Spooled Member
    142
    25
    Concord, CA
    im running almost 50 psi i dont think there is much sound proofing in prius for weight
    just crank the creedence :)
