Turning Ready light off
Discussion in 'Gen 3 Prius Technical Discussion' started by Airbalancer, Sep 13, 2009.
  1. Airbalancer
    Airbalancer Active Member
    892
    73
    Cobourg, On, Canada
    Is there anyway to turn off the ready light once the car starts to move?
  2. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Nope, it stays on once the car is running. Maybe it goes off if you turn the dimmer down all the way but if it did then you'd have no dash lights like speed etc... Not sure if it does though.
    If it bothers you enough, you could do what people did in their early GII's that had a light showing the temperature was below 37 degrees, and put electrical tape over it.
  3. bwilson4web
    15,519
    The "READY" light means the car is operational for driving. Which do you want:
    1. Not to see "READY" light but continue driving?
    2. Disable car operation while moving?
  4. Airbalancer
    892
    73
    Cobourg, On, Canada
  5. bwilson4web
    15,519
    Then you have three options:
    1. black electrical tape - you'll never see the READY again
    2. clear tape with black stripe - you'll be able to raise it if READY is a question but otherwise, blocked from view
    3. (untested) - READY may be a single line to the display from the vehicle control computer but I don't have an electrical diagram for my ZVW30 to verify this is the case. A simple switch could disable it.
    Would you pay $100 (USA) for an 'after market' solution?
    How soon do you need it?
    Are you willing to risk your Prius warranty using an aftermarket modification?
  6. patsparks
    10,664
    567
    Adelaide South Australia
    Why?
    It is no brighter than the gear indicator or any other parts of the display.
  7. Airbalancer
    892
    73
    Cobourg, On, Canada
    The car is no longer ready it is actived
    Maybe there an easter egg for it
    Would white out work? LOL
  8. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    People Get Ready
    I'm not going to bother to wonder outloud why you want it turned off. You've gotten plenty of answers to that already.
    Self hypnosis? If you perceive that it is off, then unless someone claps or snaps their fingers you'll be happy?
  9. Airbalancer
    892
    73
    Cobourg, On, Canada
    Re: People Get Ready
    Why do want the light on if you are driving:rolleyes:
    What a hard crowd today:boxing:
  10. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    My Prius often is 'ready' when no obvious noise tells me so, the engine might be off, but it will still move if I press on the pedal. For folks used to a 'normal' car, (my father has been driving 70 years) a reminder that the car is ready even though the engine is off could be a lifesaver.
    (Having the ready light go out once you are moving seems safer than just x seconds after you start it. Mind you I try to get Head lights, Cruise, Recirc and Ready all lit myself))
  11. Airbalancer
    892
    73
    Cobourg, On, Canada
    But there is road noise when you are moving and the dash is all lit up so I know car ready to do
    I been driving for 35 years, so what does age have to do anything:confused:
    It just bugs me where it is , maybe if was by the crusie light it would bug me so much
    Also when you dim the lights ready light does not dim
    Allshookup likes this.
  12. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Did you own a Prius previous to this car? If not give it time and you probably won't even realize it is there after a few months. I know I don't...
  13. bwilson4web
    15,519
    Ok, now we're getting down to some hard requirements:
    • READY or ACTIVE - it changes text (any others desired?)
    • relocatable about the cabin and display area, 2 meters radius OK
    • adjustable intensity
    This looks to be quite feasible:
    • photo sensor and light blocker - fits over the "READY" area
    • microcontroller display - generates "READY" followed by "ACTIVE" (or words of your choosing)
    • adhesive backing to mount the display anywhere within cabin, the assumption is it will only need to be within 2 meters of the original 'READY' display
    I'll work up a detailed parts list and send you the design, parts list, and estimated costs. Once I received payment for the materials, I'll order the parts, build it up, test it and send payment request for the completed unit.
    To get everything going, send me a PM with your PayPal e-mail address for the materials invoice. Then we can get this project started. Best of all, there will be no modification to the Prius electrical system so your Prius warranty will be safe.
    ROM COSTS:
    • $1.00 - photo detector
    • $5.00 - black plastic material
    • $2.00 - opaque plastic material
    • $5.00 - adhesive
    • $2.00 - shielded connector wire
    • $51.00 - PCB board layout
    • $20.00 - dot matrix, back lit LCD display
    • $20.00 - microcontroller
    • $5.00 - power regulators
    • $5.00 - resistors, caps, e.t.c.
    • $5.00 - micro-switch to cycle intensity
    • $10.00 - 12 VDC plug for power
    • ~$125.00 - material costs
    To complete the design, assemble and test will take a little labor and some consumables. This should come in at:
    • $375.00 - labor
    • $100.00 - taxes, shipping and handling
    • ~$600 - total cost
    Note, this is Rough Order of Magnitude (ROM) cost that can be off by a factor of 2 ... as high as $1,200 or as low as $300. But I will need the materials before completing the detailed design, integration and test.
  14. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    What ready light are you guys talking about anyway?
  15. Airbalancer
    892
    73
    Cobourg, On, Canada
    Thanks :D I look into it
    Really is my question any different then someone wanting the rear view camera to work when they are driving:confused:
    Also a simple yes or no really could of been enough:)
  16. radioprius1
    radioprius1 Climate Conspirisist
    1,355
    155
    Iceland
    Guys I don't like that my car moves when I am driving it. I'd rather the sensation of it being completely still when I'm doing 75mph on the interstate. Is there anyway I can make it feel like I'm suspended in a giant bladder of red gelatin instead? It really bugs me when I drive the car and it moves. Bob? :)
  17. Mark57
    2,945
    2,736
    OK
    Reminds me of DUNE. Traveling without moving . . . ;)
  18. rachaelseven
    rachaelseven New Member
    616
    212
    Adams, MA
    No.
  19. peirhead
    peirhead Junior Member
    48
    PEI Canada
    While we are at it as well as turning off the ready light once the car is in Drive (or reverse) I would also like to turn off the Airbag On light in fromt of the passenger seat.....having it on for a few seconds at startup makes sense but to leave it on all the time when someone is sitting there is annoying.
  20. spinkao
    spinkao New Member
    316
    76
    Czech Republic, EU
    You'll have to wait for the gen M (M-roman numeral 1000) :). Will include the warp drive too... :)
