Tweel: an interesting article about a new type of tire from Michelin with an accompanying video
Discussion in 'Fred's House of Pancakes' started by John321, Jun 7, 2019.
  1. John321
    John321 Senior Member
    1,457
    1,404
    Kentucky
    51,678
    interesting. would be a game changer if they pan out. i didn't see anything about mpg, but even so, if they last 3 times longer, it might be worth it.
  3. DavidA
    2,344
    1,820
    Chicago western burbs
    Glad they're still working on this after a couple dozen years. Many of the earlier problems seem to be solved, if I can believe the entire article. About all those open cells in the side of the tweels - what if you get a rock or mud stuck in just some of those? That would throw the tweel balance off badly, wouldn't it? Not a problem at slow speeds - like on a riding lawnmower, but with a car at 85mph? Not something I'd want to experience.
    I'll keep my pneumatics, and my spare, for the time being.
    frodoz737 likes this.
  4. Leadfoot J. McCoalroller
    8,037
    7,518
    Pennsylvania
    2018 Prius c
    +1 I still see enough gravel to wonder about those tweels.
    On the other hand the Bridgestone tire mentioned at the end- that's good reading. It looks like they've taken a fresh ear to tread noise, and I'm pretty curious about the results.
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,147
    Tampa, FL
    I saw a similar article a couple days ago. I can't help wondering how many times those spoke-like arms can flex before they wear out and fail.
    The other thing I'm curious about is the actual weight. They say they save weight since you don't need to carry a jack & a spare. Well, most cars already don't have a spare. And what do they actually weigh? The wording makes it sound like they are heavier than a comparable pneumatic tire, and they look like it, too. The heavier they are, the more they adversely affect the unsprung weight ratio which makes it harder to have a comfortable AND controlled ride at the same time.
    But, if they are viable, not having to be concerned about flats would be nice.
  6. bisco
    51,678
    i guess gm testing them is a good sign. 2024 seems reasonable, but you never know with new tech.
  7. will the engineer
    will the engineer Active Member
    238
    119
    LA
    2019 Prius Prime
    $300 to 400 a piece! a specialized hot product
  8. Leadfoot J. McCoalroller
    8,037
    7,518
    Pennsylvania
    2018 Prius c
    Price is fairly meaningless without knowing the service life. If that's the only set needed for the life of the car then they're quite cheap.
    Plenty can go wrong...
  9. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Not much chance these would get packed with snow and ice and go completely out of balance. Maybe they will ship with a 12V hair dryer.
    jerrymildred likes this.
  10. RRxing
    RRxing Senior Member
    2,541
    1,816
    NEPA
    The ribs can be designed at slight angle to dislodge any debris/snow/ice as they flex. At least that is how I would design 'em...
  11. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Michelin has a history of good engineering and high quality tires. I suspect they've either got a solution or will have.
    KennyGS likes this.
  12. bisco
    51,678
    gm's testing in southern michigan should be interesting
  13. What about 3D printing a winter tread pattern onto a Tweel? (Like without studs) Is that feasible?
  14. Trollbait
    12,461
    The tread portion is a removable band.The spoke section supposedly lasts three times as long as a current tire, but the treads will need replacing during that time. Once supplies and enough shops are available, it should be cheaper to get new treads than a whole new tire.
    In the comments of the article, there was someone who got to test tweels in the military. After going off road, they needed to be cleaned out, or the wheels could be out of balance. I imagine the same could happen with snow.
  15. frodoz737
    frodoz737 Top Wrench
    4,664
    2,490
    33
    "...it should be cheaper."
    Where have I heard that before? :whistle:
    The Professor likes this.
